Old 04-23-2018, 02:05 PM   #1
Vintage Copper 47
Vintage Copper 47's Avatar
Default Speedometer Replacement 47 Fordor
Ok.. so my cable & turtle are new & replaced when I rebuilt my transmission...
I know.. I know, I should have re-habbed my speedometer while waiting for my trans to be rebuilt.. it was working fine for about two months.. then just went haywire.. bouncing everywhere.. There are very few speedometer shops left in L.A... does anyone know of a good replacement mechanical speedo I can get in the 5" inch diameter?
WALT
"Old enough for the experience & too young to know better"
Vintage Copper 47 is offline   Reply With Quote
Old 04-23-2018, 02:34 PM   #2
edhd58
edhd58's Avatar
Default Re: Speedometer Replacement 47 Fordor
Mine did that, went crazy. It would go a full 360 revolution over and over. Turned out the needle was loose on the stem. Just thought I'd throw that out there.
edhd58 is offline   Reply With Quote
Old 04-23-2018, 04:20 PM   #3
1931 flamingo
1931 flamingo's Avatar
Did you lube the new cable when you put it in?? If so, with what??
Paul in CT
Old 04-23-2018, 05:52 PM   #4
38bill
38bill's Avatar
Paul in CT
That's what I was thinking. Could be a bend in the cable is too sharp also.
38bill is offline   Reply With Quote
Old 04-23-2018, 11:02 PM   #5
fordor41
fordor41's Avatar
kinked cable, unlub'd cable, too short cable and speedo head not lub'd(small hole where cable attaches to speedo head- saturate the "wick" withlight oil and turn with a battery drill).
fordor41 is offline   Reply With Quote
Old 04-24-2018, 01:54 AM   #6
Bob-93021
Bob-93021's Avatar
After going over lubing the cable etc. and if you are sure your speedo is bad I would suggest to have it repaired or find an OEM replacement. I have had a speedometer and a mechanical temperature gauge rebuilt many years ago for my MBG by West Valley Instruments in Canoga Park. I sure hope he is still in business. Morris seems to be the last of the craftsman to do these things. The place is most interesting.
https://www.westvalleyinstruments.com/
Bob
Bob-93021 is offline   Reply With Quote
Old 04-24-2018, 11:03 AM   #7
Vintage Copper 47
Bob
Bob... I was thinking about westvalley... it is actually a couple blocks from my house... He is in Reseda.. Now I just need to remove the speedo which I need a small socket with extensions.. anyone know by off chance what size nuts hold the speedo in place?
Thanks, WALT
WALT
Old 04-24-2018, 12:51 PM   #8
cmbrucew
cmbrucew's Avatar
Walt
I would guess the green spin tight. Disconnect battery first.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
