Has anyone installed the new style column support on my year and body style? After pulling the dash rail it looks completely different then the pictures posted on the forum. This car has the gas tank that is not part of the cowl and has the access panel on the firewall. It appears I would be bolting the new support to the gas tank flange! Not a good thing! Is this conversion do able on this year and body style?
#2 | |
![]() Quote:
In May 1931 the steering column support as a bolt on support, no longer attached to the gas tank, was introduce by Ford. It will retrofit all 1930-31 cars, but is not a bolt on fit for 1928-29. I am wondering if you have a 1930-31 support.
I have no access to vendors catalogs today, but I believe about 2 years ago one was offered by Snyder and likely other dealers also, for the 1928-29 cars, a bolt in place fit. The basic part number with Snyder's would be 3520 I believe. |
Ok, maybe I worded this wrong, I know that 30/31 added support will bolt to the existing dash bolt pattern. To mount the added column support to a 28/29 you need a 1 x 7 x 3/8
steel or aluminium spacer because the bolt pattern is different. I know all this. My question is has anyone installed this extra column support on a 29 Briggs 4-door or a car with a drop down gas tank, the type of tank that has a filler panel on the firewall. The area where you would bolt the new column support to the dash main frame seems to be different on a car with the drop down tank, it has no support to mount to. |
I know the voices aren't real but damn they have some good ideas! ![]() |
