Old 03-04-2018, 08:12 PM   #1
coolcoupe
coolcoupe's Avatar
Default battery
Wondering what amperage I should be looking at for a battery disconnect for my 47 Monarch ? Thanks for now,, Moe
coolcoupe is offline   Reply With Quote
Old 03-04-2018, 08:17 PM   #2
tubman
tubman's Avatar
Default Re: battery
If it's still 6 volts, OPTIMA - 800CCA. Unless you're just going to show it. 12 volts? Just about anything that fits will work.
Old 03-04-2018, 08:19 PM   #3
HDowse
HDowse's Avatar
Default Re: battery
I bought the stock battery disconnect that I mounted on the firewall from Joe's in MA. No problems, seems to carry the 6volt starting draw just fine.
HDowse is offline   Reply With Quote
Old 03-04-2018, 08:21 PM   #4
paul2748
paul2748's Avatar
Default Re: battery
Ar you looking for a battery or a disconnect for the battery? If a disconnect, I use a 1/2 inch wrench - just loosen the nut on the ground cable and take it off. Works every time and nothing goes bad or breaks
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 03-04-2018, 08:25 PM   #5
coolcoupe
coolcoupe's Avatar
Default Re: battery
Sorry, it's 6 volt. I wanted to know how low in amps can I use or what was the normal that was used.
Old 03-04-2018, 08:38 PM   #6
JSeery
JSeery's Avatar
Default Re: battery
It has to be able to carry the full amp load on the battery you are using. CCA (Cold Cranking Amperage) might be a good guide.
Old 03-04-2018, 08:47 PM   #7
coolcoupe
coolcoupe's Avatar
Default Re: battery
Thank you, JSeery. That's what I needed. What a great forum for knowledge !!
Old 03-04-2018, 10:23 PM   #8
JSeery
JSeery's Avatar
Default Re: battery
More correctly, it would be the the current draw of the starter. That would be the maximum load the switch would see.
Old 03-04-2018, 10:47 PM   #9
fordor41
fordor41's Avatar
Default Re: battery
I bough a disc. sw from a big time auto electical supplier and when I got it home it said 35A. I called them and asked about starter amp draw thru the switch. He seemed to not know how much a starter could draw. Then said " the boss has one on his car and doesn't have any problems". I don't run the starter thru mine! everything but.
fordor41 is offline   Reply With Quote
Old 03-04-2018, 10:57 PM   #10
JSeery
JSeery's Avatar
Default Re: battery
The switch should have an instantaneous rating and a continuous rating. 35A would sound like a continuous rating,
Old 03-05-2018, 06:41 AM   #11
koates
Default Re: battery
Starter current draw could be around 350 amps depending on battery condition, starter motor condition and engine load, and how fast the engine starts up. A switch capable of handling 350 amps for around 15 seconds cranking at a time would be a good start for a 6 volt ford flathead system. It would have a continuous rating of about 100 amps. Look for a truck type all metal housing type and not the cheap plastic housing type which are very marginal in quality. Of course the heavy duty ones cost a lot more. The one I use is rated at 1000 amps and has large brass contacts and terminal studs. Regards, Kevin.
koates is offline   Reply With Quote
Old 03-05-2018, 02:05 PM   #12
coolcoupe
coolcoupe's Avatar
Default Re: battery
Hi Kevin, Can I ask where you purchased your's and the make/model number ?
I can't seem to find a vendor up here in Canada that has one like you mention.
I do want to install a heavy-duty one. Thanks for now, Moe
Old 03-05-2018, 02:22 PM   #13
JSeery
JSeery's Avatar
Default Re: battery
I'm not Kevin But in general Boat Supplies or Heavy Truck Supplies should have a selection. Should be a lot of both in Canada I would think.
Old 03-05-2018, 04:06 PM   #14
50fordcoupeman
50fordcoupeman's Avatar
Default Re: battery
JSeery............would a knife-blade type disconnect be a suitable choice? I have used those before with no problems but I don't know what the amp rating was.
50fordcoupeman is offline   Reply With Quote
Old 03-05-2018, 04:29 PM   #15
JSeery
JSeery's Avatar
Default Re: battery
It would work fine if it is heavy enough to carry the current. Just as a general guess, the cross-section of the parts would need to be in the same range as the cross-section of the positive or negative lead to the battery. The issue I would see is keeping it protected as it would have a lot of open area.
Old 03-05-2018, 04:33 PM   #16
50fordcoupeman
Default Re: battery
Thank you!!
