Old 12-17-2017, 04:50 PM   #1
trahilaloid
Default End of distributor shaft ground away
So on my 292 y block my distributor was giving me problems with the advance so I yanked it since I already had the heads off and where it goes into the oil pump drive shaft looks like it has been grinding any ideas on why this happened doesn't look like the pump drive shaft is hurt it was the original distributor the truck has 19 thousand it's been sitting since 87 bought off this really old lady for 500 bucks said it was her sons poor guy commited suicide 30 years ago and she finally wanted to let it go as long as I got it running and kept it
Sent from my XT1609 using Tapatalk
trahilaloid is offline   Reply With Quote
Old 12-18-2017, 05:11 AM   #2
KULTULZ
KULTULZ's Avatar
Cool Re: End of distributor shaft ground away
The only conjecture ... ... I have is that at some point someone was having trouble putting it back in (noticed an interference) and had to modify it.
That is taking into consideration that the dist housing bushings and oil pump were good.
"Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'."
― Charlene Darling (Daughter of Briscoe Darling)
KULTULZ is offline   Reply With Quote
Old 12-18-2017, 11:41 AM   #3
dmsfrr
dmsfrr's Avatar
Default Re: End of distributor shaft ground away
Not sure why someone would do that, but as long as it has no rough edges I suspect it will be fine.
There shouldn't be any real side play in that shaft unless the bushings are shot.
