What are the pros and cons of Lincoln flatheads, parts interchangeability, design issues etc? I don't know anything at all about them. I am just wondering if they offer any advantage?
No real ones that I can think of. Big, heavy and few speed parts available . . . so in the end, unless you REALLY want one, probably not worth it (unless you have an original Lincoln car).
Hi, are you referring to the 337" Lincoln V8's or the flathead V12's?
If you are asking about the 337 V8 let me get in here quick before the naysayers shoot it down. The 337 is a large and advanced Ford Flathead engine. There are features on the 337 that are very good. A few key ones are obviously the ample cubic inches. To go with the added cubes there are improvements to the breathing of the engine to feed those cubes. The negatives are that they are bigger and heavier than the regular Ford Flathead. They are about the same size as the Caddy flathead V8's but better. Nobody bats an eye about their heft and the Cads were used in some hot rods back in the day. The Lincoln 337 engine conquered "La Carerra Pan Americana" a couple times powering the cars through a tremendous torture test. |
The cars were not powered by a 337 Flathead but by an OHV engine first used in 1952.
#5 | |
We
The 52 ohv was either a 279 or a 317 and looks like a big Y block. Same deal lincoln cars and ford F7 f8 trucks starting in 1952.I had two big trucks with them . A 55 ford tandem t750 and a 61 ford F800. Or did you mean the winning road race car was a 52 lincoln and they never raced the flathead lincoln? |
#7 | |
![]() Quote:
There are pictures of these 337 Lincolns getting airborne during the race. They couldn't have been all that bad. |
Those Olds V8s were ONLY 303 CU IN. DD
#11 | |
![]() Quote:
#12 | |
![]() Quote:
In retrospect, just finishing that race may be considered "conquering". |
#13 | |
![]() Quote:
There is a picture on the internet of a 337 powered Lincoln racing in the Carrera Americana actually "catching air" going over a rise in the road. Not bad. |
#14 |
#15 |
Very little interchangeability between the 337 and other Ford flatheads. Carburetor parts and a few ignition parts and that's about it. They also used a solid tappet version in trucks but only in the very large F7/F8 classes. Damn good truck motor but a bit too heavy for a car unless it was built for it like the big 49-51 Lincoln Cosmos and baby Lincolns. They had a few more inches in the engine compartment than the Mercs to house the big thing. They also used different transmissions, clutches, and rear axles.
#16 | |
![]() Quote:
rods. There was speed equipment made for them but may be a little hard to find now. It's one of the smoothest running engines. G.M.
www.fordcollector.com |
#17 | |
![]() Quote:
http://www.route66hotrodhigh.com/BBF-Flathead.html http://www.vanpeltsales.com/FH_web/f...s-337bigV8.htm Here are a couple pictures I took of a little track roadster at TROG West, Pismo Beach, Ca, in October. The 337 engine did not look that big or out of place to me in this roadster. Also, we saw Austin finned aluminum heads, and multi carb intakes for the 337 on the shelves for sale at H&H Flatheads.
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 12-19-2016 at 01:58 AM. |
#18 |
Another plus is you get to sing "Hot Rod Lincoln" while your driving down the road.
There is no substitute for cubic inches........ |
#19 |
They are about 25% bigger so not huge in that way.
The big issue is that they are built for torq and there´s a lot of rotating mass in them. If you want to convert one for speed in a light car i figure you have to start cutting down the weight to get a real fun engine out of it. |
#20 |
Interesting thread. It makes you wonder why Ford invested in an engine that was only used for four years?
