Old 12-10-2024, 01:27 PM   #1
rockfla
rockfla's Avatar
Default Right Hand Drive engine tins
Any of our "right hook" members have pictures you could share of how the engine tins bolt up on a RHD 1935 frame??
Old 12-11-2024, 02:00 AM   #2
mercman from oz
mercman from oz's Avatar
Default Re: Right Hand Drive engine tins
RHD 1936 Ford Engine Splash Pans
Old 12-11-2024, 07:58 AM   #3
rockfla
rockfla's Avatar
Thanks for the post Trevor, as you can see, I have two sets and unfortunately both right side tins have been hacked on, one more so than the other and is taking some "extensive" fab work to rebuild. My other right hand tin wasn't so bad and was a more "minor" repair......BUT I was hoping to get pictures of them "bolted" to the frame? Thanks again and take care Trevor
Old 12-11-2024, 09:27 PM   #4
Brian
Brian's Avatar
Sorry, it's been years since I had those things on my car, memory is a bit fuzzy, but the LH one bolts onto the top of the chassis rail with three 1/4" bolts/nuts. spring washers, the three holes are evident in the chassis rail. The one that goes around the steering box is a 'fiddle' to fit, can't remember all the details, I 'think' you have to drop the pitman arm, and from memory it bolts to the bottom chassis rail. Again, the holes are in the chassis rails, get under the car and compare the splash shield with the holes, it should become evident. That particular one is a curse, particularly when you try to access starter motor. Good luck! enjoy the exercise.
Old 12-12-2024, 01:53 AM   #5
mercman from oz
1936 Ford Engine Splash Pans - Underside View
Old 12-12-2024, 02:53 AM   #6
mercman from oz
Close-up Shot of Right Hand Splash Panel.
Hope these pictures help you in your repairs.
Old 12-22-2024, 05:24 AM   #7
danliveshere
danliveshere's Avatar
Sorry Robert that fordor chassis only has the front pan on it. I’ll have a look over Christmas if I have the left and rhs put away. Dan
danliveshere is offline   Reply With Quote
