Old 09-04-2017, 10:00 PM   #1
Licensed to kill
Licensed to kill's Avatar
Default surge tank, yay or nay
Thinking of adding a surge tank (overflow tank) to the rad on my model A. Good idea, bad idea, stupid idea???
Licensed to kill is offline   Reply With Quote
Old 09-04-2017, 10:08 PM   #2
daveymc29
daveymc29's Avatar
Default Re: surge tank, yay or nay
I had one but took it off as when I pressurized my radiator to 2,5 psi it never got any water into it.
daveymc29 is offline   Reply With Quote
Old 09-04-2017, 10:16 PM   #3
Drive Shaft Dave
If the radiator has good downflow through it I see no reason for it. As long as you keep the coolant level just below the baffle it should be good.
Drive Shaft Dave is offline   Reply With Quote
Old 09-04-2017, 10:22 PM   #4
Licensed to kill
The only reason I'm thinking about it is so the rad would stay full rather than being down a couple inches when cold.
Old 09-04-2017, 10:38 PM   #5
Drive Shaft Dave
As long as the coolant is cvering the tops of the tubes you will be ok, there will be room in the top tank for coolant expansion.
Old 09-04-2017, 10:41 PM   #6
Mike V. Florida
Mike V. Florida's Avatar
Not needed.
Old 09-04-2017, 10:48 PM   #7
40 Deluxe
Smile Re: surge tank, yay or nay
Originally Posted by Mike V. Florida View Post
Not needed.
Well, if you go drag racing, the track will require you to have a surge tank so you don't put water/antifreeze on the track surface!
Old 09-04-2017, 11:19 PM   #8
marc silva
marc silva's Avatar
Correct me if I am wrong, but I thought the water would only get drawn back into the radiator if it was a closed system. The tank on the stock model A would only act as a "catch" tank basically keeping it from spilling out on the ground until it got full then dumping on the ground anyway. ???
marc silva is offline   Reply With Quote
Old 09-05-2017, 04:33 AM   #9
Tom Wesenberg
Tom Wesenberg's Avatar
A hose from the overflow tube to the bottom of the overflow bottle will work, and get sucked back as the coolant cools down, unless you have a leak in the cap gasket. I did this on mine when I had coolant loss problems, and was trying to figure out what was wrong.
Old 09-05-2017, 07:00 AM   #10
Jacksonlll
Jacksonlll's Avatar
I have one on one car and none on the other. My problem is that the cap is not sealed tight enough to pull the coolant back into the radiator during cool down. So, I guess mine is a catch bottle.
Old 09-05-2017, 08:00 AM   #11
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Yes, you are 110% correct on all points.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 09-05-2017, 02:10 PM   #12
1931 flamingo
1931 flamingo's Avatar
On mine I "sealed" the cap on the o/flow tank, it sucks back.
Paul in CT
Old 09-05-2017, 02:18 PM   #13
mike657894
mike657894's Avatar
not needed as it wasn't designed to have one. the tubes do the cooling not the end tanks. you are just used to a side ways radiator that would be filled because the top of the tank and tubes are near even.
mike657894 is offline   Reply With Quote
Old 09-05-2017, 02:42 PM   #14
dumb person
dumb person's Avatar
If you sealed the cap with an o-ring this should be fine.
Legend has it if you use an overflow bottle like this your coolant will have less exposure to oxygen (as only the surface area of the bottle level will be exposed to air, and only a limited amount will be sucked back into the system.)
So, less corrosion in your block, basically.
<Link> This is how we roll<Link>
"I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob
Outcasts rules of old cars
#1 Fun is imperative, mainstream is overrated
#2 If they think it is impossible, prove them wrong
#3 If the science says it impossible you are not being creative enough.
#4 No shame in recreating something you never had
#5 If it were not for the law & physics you would be unstoppable
dumb person is offline   Reply With Quote
Old 09-06-2017, 06:04 AM   #15
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
With a perfectly sealed cap & a LARGE enough overflow tank, hosed to the overflow tube, you can keep the radiator VIRTUALLY FULL. Thus increasing the water capacity & eliminating AIR BUBBLES & increasing the EFFICIENCY of the system!
The INVENTOR of the QUICK, add-on system was a mechanic for Navajo Truck Lines, in the Southwest. Trucks were running HOT! By adding a clear plastic tube in the upper hose, he determined that FOAM & BUBBLES were the CULPRIT!
After setting up the tank system, the water ran CLEAR & they ran COOLER!!!
I was in the "heyday' of these add-on tanks & I do KNOW what I'm TALKIN' about.
Bill Restofthestory
"THE ASSISTANT GURU OF STUFF"
Old 09-06-2017, 11:28 AM   #16
Scottio57
Scottio57's Avatar
I live in the desert and it gets over 110 for most of the summer. I have the stock car and drive it year round and have no heating or water purging problems at all. Once a year I flush the cooling system. Fill it up and let it find its own level. After that I check it just to make sure it is covering the radiator tubes.
Scottio57 is offline   Reply With Quote
