Old 07-17-2017, 03:51 PM   #1
zippi
zippi's Avatar
Default *1937 Pickup Windshield Regulator*
I'm going to have the rubber seal and glass replaced on my 37 before winter hits and I want to get the Winshield working to get some fresh air in. Looking through the windshield I can see that the regulator seems to be there but the handle on the dash just spins around. My question is, do I need a new regulator? Plus, when I take it in to have the glass and seal replaced is this something the glass shop can unbolt and bolt the new regulator in?
zippi is offline   Reply With Quote
Old 07-17-2017, 04:32 PM   #2
SofaKing
SofaKing's Avatar
Default Re: *1937 Pickup Windshield Regulator*
The handle may be stripped on the shaft, probably fix by drilling a hole and use a roll-pin through handle and shaft; or the gear drive on the regulator is stripped/ broken and I don't know the most probable failure mode on that regulator. Has the windshield be sealed closed? To R&R the regulator you need to remove the top panel off the dash and hold regulator mounting nuts from underneath the dash.
SofaKing is offline   Reply With Quote
Old 07-17-2017, 06:01 PM   #3
zippi
zippi's Avatar
I don't know if the windshield has been sealed shut or not. It might just be stuck from age. The top panel of the dash looks like it is held in with 3 sheet metal screws on each side. Looks like I Can't get to them unless the windshield is open at the bottom. Could I try and pop the windshield out at the bottom from inside or is that a bad idea if it has been sealed shut? If it is sealed shut, how would a fellow go about getting it open?
Old 07-17-2017, 07:05 PM   #4
1931 flamingo
1931 flamingo's Avatar
Pictures, we like pictures.
Paul in CT
Old 07-17-2017, 07:21 PM   #5
zippi
zippi's Avatar
Here are a few pics. I can't find a regulator for a 37 but I did a regulator for the 35 & 36. Will the 35-36 work on the 37?
Old 07-17-2017, 07:22 PM   #6
zippi
zippi's Avatar
Pic 2
Old 07-17-2017, 07:23 PM   #7
zippi
zippi's Avatar
Pic 3
Old 07-17-2017, 07:24 PM   #8
zippi
zippi's Avatar
Pic 4
Old 07-17-2017, 07:42 PM   #9
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by zippi View Post
I'm going to have the rubber seal and glass replaced on my 37. When I take it in to have the glass and seal replaced is this something the glass shop can unbolt and bolt the new regulator in?
I sincerely hope this turns-out GOOD for you, but I have an ugly feeling that this ain't gonna be a pleasant experience. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 07-17-2017, 08:04 PM   #10
v8fordman
v8fordman's Avatar
No, the '37 regulator is different than the others. I think you may be in for replacing the regulator, but I would check the handle first. It comes off when you remove the dash cover and you will see how if it held on with a lock ring.
v8fordman is offline   Reply With Quote
Old 07-17-2017, 08:32 PM   #11
37 truck
I have my 37 all apart, I will take a look at the dash cap, regulator, and take pics for you
37 truck is offline   Reply With Quote
Old 07-17-2017, 08:33 PM   #12
zippi
zippi's Avatar
How does the dash panel come off? I can see 3 screws on each side through the windshield but see no way to get to them.
Old 07-17-2017, 08:34 PM   #13
zippi
zippi's Avatar
That would be great. Thanks.
Old 07-17-2017, 08:48 PM   #14
JSeery
JSeery's Avatar
Well, looks like it was painted with the windshield closed. Might try Barnfind08 or the regulator guy for NOS. REGULATOR ROY 609-828-8537 from a recent window post.
Old 07-18-2017, 02:21 PM   #15
zippi
zippi's Avatar
Are these the screws (circled in red) that need to be removed in order to remove the dash panel? If so, how do you remove them when I can't get the windshield to crank open at the bottom?
Old 07-18-2017, 03:54 PM   #16
zippi
zippi's Avatar
Just got home from work and had a little time to check the windshield before we head to the county fair to watch the grand kids show their 4-H animals. I can pop the window from the inside at the bottom corners and the frame moves so it doesn't look like the windshield is sealed in. If I just knew how to get that dash panel out I could check out the regulator and at least see if I can get the windshield to open a little.
Old 07-18-2017, 04:34 PM   #17
40cpe
40cpe's Avatar
It sounds like the regulator is holding it closed. Can you reach the screws that hold the regulator arms to the windshield frame? If so, remove them and the windshield should push open.
Old 07-18-2017, 04:52 PM   #18
V8COOPMAN
V8COOPMAN's Avatar
Click the link below for a thread that MIGHT help you see what you're working with. DD
https://www.fordbarn.com/forum/showt...ield+regulator
T5 W/TORQUE TUBE
Old 07-18-2017, 05:22 PM   #19
38bill
38bill's Avatar
OK, I believe the '37 dash is very sim to my '38 so here goes. Look under the bottom edge of the dash overhang. I believe that you should find the screws that hold it to the dash. You will probably have to remove the interior pillar trim on each side of the windshield first as they may sit over the edge of the top of the dash panel. Note that the window crank comes off with the dash top panel. You do not have to remove it first as it should slide off the windshield crank shaft. Remove these pieces and you will have access to the crank mechanism.
38bill is offline   Reply With Quote
Old 07-18-2017, 05:29 PM   #20
flatford8
flatford8's Avatar
The crank mechanism is right there in post #15. Or is that not your truck?..... Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
