I have a top radiator tube on my '30 Model A that has a persistent leak. Have replaced the hose and used Permatex #2 between the hose and the tube. With the hose removed, the connector tube is dented and a bit out of round which I suspect might be from over zealous tightening of the hose clamp. Is there anything I can do to straighten out the top tube?
Steve A. Chicago, IL 1923 Ford Model T Depot Hack 1924 Dodge Bros Roadster 1929 Franklin 130 & 135 1930 Ford Model A Speedster 1932 Detroit Electric 1939 Ford V-8 Deluxe fordor 1946 Chevy 3600 Pickup 1948 Chevy Fleetmaster Sport Coupe with Wood Kit 1950 Studebaker Champion Starlight 1953 Dodge B4B pickup 1963 Chevrolet Corvair Spyder convertible |
I used a exhaust pipe expander from Harbor Freight to make mine round again. Be gentle.
As I expanded it, I tapped on it lightly with the side end of long socket extension. Last edited by Fred S; 04-24-2017 at 10:38 PM. Reason: More info |
Best bet.
I inserted a short piece of exhaust pipe into the radiator top and bottom tubes to strengthen them and make them round again. The exhaust pipe outside diameter needs to match the inside diameter of the radiator tubes. I left them in, so I can tighten the hoses better. No leaks ever.
AL in NY |
