Old 04-07-2017, 08:58 AM   #1
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Default Loadamatic info.......Bubbas
Just a note or two regarding the 49-53 Loadamatic distributor with Vacuum only advance???
https://www.facebook.com/main1330/ph...type=3&theater
As this is a vacuum only distributor advance the diaphrahm must be working perfectly. Has two springs moving a point plate against "venturi vacuum| NOT manifold vacuum. Carb adjustment must per perfect as well to provide proper degrees of advance when needed.Springs are hooked to off center pins for adjustment...Carb usually gives .5 to 3 inches of venturi vacuum....
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
