What am I missing or overthinking here.
This is off my 42 G six cylinder. I have had several instances where either the generator is moving or the belts loosen greatly, and I am betting on the generator moving after I've tightened it down good. Once this caused overheating to the point of boil over. When I pulled it off the car the first time it had two same size bolts with a pile of washers over that weird shaped hole. This is also as real pain in the *&^ to get both belts tight and hold everything in place as you're tightening the bolts. Is there something I am missing, overlooking or is this just a bad design. Next question is what can I do about the odd shaped hole? I am considering a piece of flat 1/4" thick steel made to cover that odd hole instead of washers. |
My generator has a washer with two holes.. basically to match/fit the pivot hole/slot & adjustment slot...
That keeps equal pressure on both parts of the bracket from moving.. It will be hard for me to take a photo as you know, I am still using the bracket to support my alternator bracket.. Try making a long oval washer out of 1/8 flat bar stock with the holes just large enough to fit the bolts and aligned to fit both slots.. that should do it. WALT |
Good photo Mark... mine was greasy but not rusty... LOL
