my brother bought a '23 t race car altered and it had spindle mount front wheels. he wanted to put those 10 spoke "gasser" wheels on, but he didn't have a hub to mount it to. i have a hub and after all is said and done they look great on his car. now here is the problem. his spindle is the rectangle model A without a cotter pin hole. i have looked at parts stores and they look like they have 2 different castle type nuts. is one or the other for this situation? also the reason i am posting on the Ford Barn site is very few people would use model A spindles there i would think.
I have never seen a spindle without a cotter-pin hole. Having said that doesn't mean they don't exist. You could drill a hole in the spindle with a little care. FYI 1948 nuts are thinner and a larger hex than earlier nuts.
Could the hole "possibly" be plugged with cotter remains, from when someone removed the nuts, WITHOUT removing the cotter pins??? I've seen that happen.
Bill W.
i think there is a good chance that there is a cotter key hole if you examine it closer. Wayne
yea it can be tricky to spot and Ive had to do this alot to alot of different nuts and bolts on my AA. And im with the other guy - ive never seen any spindle new or old without a cotter pin hole either.
Coral Springs Florida ![]() |
well thanks for the replies guys. my brother will be coming over in a week. we will have to remove a wheel and look closer.
DO NOT DRIVE CAR WITH OUT COTTER PINS! yes i am yelling at you, I dont want any one hurt. Putting my soap box away.
More info please about the thinner nut. I retorqued the rear nuts to 90#. Now the hubcaps won't go on because of the cotter pin bent on top of the nut. A thinner nut may solve the problem. I could cut off the end of the axle but the cotter pin hole is only three threads from the end. Any suggestions?
bend the cotter to the sides of the nut, not the top
how did it work before you retorqued please do not cut the axle
'31 180A |
What car is the front end/spindles from ?
I don't domestic Ford's ever used them but clamp type spindle nuts are not that uncommon |
1948, and maybe 46-48, had larger front and rear axle nuts. Not sure of the sizes but smaller nuts may be the answer to captdan's problem? If the cotter pin is the problem, cutting the axle will not solve the problem.
#13 |
#14 | |
![]() Quote:
