Old 05-21-2016, 02:47 PM   #1
aermotor
Default Front brake opearting arm
The front brake operating arm should be 15 degrees forward. I am getting between 30 and 15 degrees forward free play with the brake rod disconnected - is this normal?
John
aermotor is offline   Reply With Quote
Old 05-21-2016, 03:42 PM   #2
wrndln
Default Re: Front brake opearting arm
I think 30 degrees so too much. Maybe the internal rod inside the kingpin is to long. Did you use a "pill" in the operating wedge. 15 to 20 degrees is about all than it should be in my opinion. You suppose you could grind off a little of the operating pin, but you shouldn't need to.
Rusty Nelson
Old 05-21-2016, 04:24 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
The amount you can move the lever forward doesn't count. You lightly pull back and measure, and hope it's about 15 degrees.
