I have a 33 Pickup. I have a 33 rear axle. I have a B 32 4 Banger. Can I use a Model A tranny or must I use a 33/34 Transmission?
Thank you. |
you need 32--34 -----I won't say that the "A" trans can't be put in--but it won't be a bolt in thing---you can put later gearsets in the 32-34 case
I would buy a kit from Clings to use a v-8 trans. I did it to my 29 coupe and it was the best thing I have done. I used a 39 trans. Everything was a bolt on.
Respecting and Resurrecting Ford Model A's. |
#4 | |
![]() Quote:
Charlie Stephens |
#5 | |
![]() Quote:
Charlie Stephens Last edited by Charlie Stephens; 12-25-2015 at 11:10 PM. |
Friend has several flatheads but he does not know condition. All stored indoors. A 1936, Post war 59AB and 8A. From your comment Charlie - I should ID the rearend and tranny in the pickup first then go from there. I mentioned the Banger because it's completely rebuilt with adjustable valves.
#8 | |
![]() Quote:
Charlie Stephens Last edited by Charlie Stephens; 12-26-2015 at 12:07 AM. |
Thanks Charlie. Big help. Yup it's a V8 tranny. I do have Big Truck bell housings that have the hump - would they work to adapt one or the other? Do you have a personal email? I can send you pictures.
#10 | |
![]() Quote:
Charlie Stephens Last edited by Charlie Stephens; 12-26-2015 at 02:55 AM. |
Itchy-Pit,
If you decide to go with the 1932 4 cylinder engine you have you will need to look for the following (depending upon how close to original you want to be). Water pump (’33 is shorter) Crankshaft pulley (’33 is shorter) Timing gear cover (mounts the generator further back) Motor mount (’33 is wider) Exhaust system back to muffler Radiator (or have your V8 radiator modified) Radiator support rods (check this, they may be different 4 to 8, they were in ’32) Engine steady rods (I assume they were different 4 to 8 but check) Hubcaps Starter (if your existing ’32 starter is designed to be used with a pull cable) Transmission (if your gears are good you can put them into a 4 cyl case) Flywheel housing (’32 and ’33 are different) Choke (my guess is that the 4 cylinder uses a cable like the ’32) Accelerator linkage (different 4 to 8) Engine splash pans Relocate gas line from right to left side of truck) Torque tube and drive shaft (or complete rear end) You need to accept the fact that your serial number starts with “18” which means V8 Exhaust manifold (the A might work with longer exhaust pipe) Almost enough to make you want to stay with a V8. If you sell the truck it will be worth more as a V8. My choice would be a ’33, a 1936 (with insert bearings, some had babbet), a 1937-38 21 stud and 38-48 24 stud engine in that order. Any flathead (except the V8 60 which you don’t want anyway) will bolt up to the transmission you currently have in the truck. As time went on the transmissions improved slightly with the best being in 1939. The later gears will go into most cases but sometimes it takes a little work to get them into the earlier cases. The later cases will also take a larger clutch if that is important. The latest cases had the number “78” cast into them and unless you are doing a total restoration you are better off with that case. The 1949 and up engines will require a flywheel housing from a truck (or maybe a Mercury?) to bolt up to the earlier transmission. One final thought. Be sure to get the truck registered (and the number on the frame matches the registration) before you start working on it. Once it is registered you can put it into a non operational (NON OP) status with the DMV and there will not be any yearly fees. The early registration is important since you want the truck at its lowest value for tax purposes and you want to be sure the truck is really yours and someone else will not try to claim it. Charlie Stephens Last edited by Charlie Stephens; 12-28-2015 at 01:24 PM. |
