Hi Ladies and Gentlemen, I am starting a frame-up restoration and noticed the front spring assembly has 11 leaves, but the rear assembly has only 9 leaves. I assume this may be due to more weight at the front of the car. Is this normal, or were two leaves probably broken and subsequently removed? Thanks very much, Wayne
It depends on the body style, light cars like roadsters got less leaves that say a heavy station wagon ---you need a parts book ---at least list what body you have so you can get proper information --in some years the delux cars got covered springs, standard uncovered also -----but when the cars were "just old cars" any spring would work
Thanks for the prompt reply, Kurt. This car is a fordor (a four-door), but I'm unsure if it's a standard or deluxe model. Can I determine that from the serial number? Also, can you suggest a good place to obtain a parts manual? Thanks, Wayne
#4 | |
![]() Quote:
You are correct however, that the amount of leaves was dependent / respective of model.
#5 | |
![]() Quote:
It was nearly always built with a ten leaf spring on the rear. On rare occasion a '40 was built with a heavier rear spring having eleven leaves.
#6 | |
The "green book" will have better listings and will give numbers for the spring you need |
#7 | |
![]() Quote:
There is nothing you can determine from the serial number. All engines were made at the Rouge Plant. After they passed final inspection they were shipped all around the United States and to some foreign assembly plants that did not make their own engines (some did). The standard had vertical grill bars like the '39 deluxe and the deluxe had horizontal bars. Go to http://www.socalefv8.org and look under "Cars of the Early Ford V8 Years" for pictures of the '39 deluxe grill (which became the '40 standard) and the '40 deluxe. You can find a lot of other differences in the restoration guidelines from the Early Ford V8 Club (earlyfordv8.org) and I suggest you invest in a copy. Charlie Stephens |
