Old 08-10-2015, 10:19 PM   #1
Lowell Fast
Default oil pan
Need clues on how to remove splash (dip) pan from the inside of the oil pan.
Lowell Fast is offline   Reply With Quote
Old 08-10-2015, 10:26 PM   #2
garyaodell
Default Re: oil pan
Drop it flange down on the floor a few times.
garyaodell is offline   Reply With Quote
Old 08-10-2015, 10:27 PM   #3
Mike V. Florida
Mike V. Florida's Avatar
Default Re: oil pan
Take a wood dowel and using the oil pump hole pry it out (I use garyaodell's method my self)
Old 08-10-2015, 10:28 PM   #4
lesbliss
Default Re: oil pan
Just turn pan upside down and drop on the ground. Should pop right out.
lesbliss is offline   Reply With Quote
Old 08-11-2015, 01:23 AM   #5
Charlville
Charlville's Avatar
Default Re: oil pan
A little video here:
http://automotiveamerican.com/2015/0...ffle-cleaning/
Just make sure you drop the pan onto a forgiving surface and it should pop right out
Mine was really sludged up!
https://automotiveamerican.files.wor...3/img_4660.jpg
Kevin Flood
West Berkshire UK
Member MAFCGB, VHRA, SAH, Brooklands Trust
Sporadic progress on My 1929 Sport Coupe can be found here along with my blog
Charlville is offline   Reply With Quote
Old 08-11-2015, 11:31 AM   #6
burner31
burner31's Avatar
Default Re: oil pan
What's the biggest hammer you have?
Take that hammer and shake it at the car/part, using good strong choice words, telling the car/part what you want it to do.
Set the hammer down then follow the instruction given in the posts above.
"If you don't threaten your Model A every now and then. they think you don't love them"
Keith
Shawnee OK
'31 SW 160-B
Old 08-11-2015, 11:44 AM   #7
160B
160B's Avatar
Default Re: oil pan
I use an old handle from a sledge hammer or other large handle , put it in the oil pump cut out and pop the tray out of the pan. I have done this several time and it works great.
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 08-11-2015, 08:28 PM   #8
hale1776
hale1776's Avatar
Default Re: oil pan
Focus on one side when that is out your home free.
hale1776 is offline   Reply With Quote
Old 08-11-2015, 08:48 PM   #9
SeaSlugs
SeaSlugs's Avatar
Default Re: oil pan
agreed, lay down a tarp or use part of the yard that refuses to grow anything, i slammed mine on the ground a few times and popped right out.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
