Old 08-13-2015, 08:29 PM   #1
Joe/Ct
Joe/Ct's Avatar
Default Transmission Oil Cloudy
I just had the transmission rebuilt on my '28 roadster, and had 600W oil added. After driving for a few weeks, I checked the level. Upon removing the fill cap, the fluid ran out the fill hole and was cloudy/milky. Is this normal? If not, what does it indicate and what is the remedy?
Joe/Ct
"The older I get, the better I was"
Joe/Ct is offline   Reply With Quote
Old 08-13-2015, 08:54 PM   #2
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Default Re: Transmission Oil Cloudy
Drain that dude & fill it with 140W, quality gear oil. WHY do we mess around with everybodys' WEIRD gear oil CONCOCTIONS? They're gettin' RICH off us, there are NO "MIRACLE" LUBRICANTS.---Just like making SOUP, if you put TOO MUCH CRAP in it, you SPOIL IT.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 08-13-2015, 10:25 PM   #3
Mike V. Florida
Mike V. Florida's Avatar
Milky look is usually water in the lubricant. Drain it, refill it and see what it does.
Old 08-14-2015, 01:41 AM   #4
WestCoast
Bill, your right use 140w, I cant believe these guys are still going by an 85 year old spec book, as others said, water in trans, maybe thru the vent hole, or thru the top shifter plate
WestCoast is offline   Reply With Quote
Old 08-14-2015, 03:00 AM   #5
Mike V. Florida
If using 85 year old parts, why not 85 year old specs?
Old 08-14-2015, 06:38 AM   #6
BILL WILLIAMSON
BUT, in 85 years, we've developed BETTER oils & lubricants & DON'T use VASELINE on your distributor cam, jist cuz Henry sed so!
VASELINE is for the BEDROOM!
Bill W.
Old 08-14-2015, 07:46 AM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
But oil is millions of years old, and was refined in the past year, so I'll stick with the thick stuff originally recommended. It helps to slow the gears for better shifting. I've seen some of the dealer mixed oil that is almost black, like dirty oil. I don't know what's in it, but haven't heard of any problems related to it, but I'll keep buying the Mobil 636 from the local bulk oil dealer.
Old 08-14-2015, 07:54 AM   #8
jimvette59
jimvette59's Avatar
I have a question could the new oils be foaming and creating a problem ?
I also would like to know if the new 600 W be foaming . Does the Mobile 636 have a anti foaming agent like some race cars use ?
jimvette59 is offline   Reply With Quote
Old 08-14-2015, 08:34 AM   #9
Gold Digger
It don't seem right about water or moisture mixing with 600W oil. 600W is what we use in the lubricators on steam engines and if it gets spilt or used for lubrication on an engine a steam cleaner want clean it off. It takes kerosene or gasoline to clean it off, water want cut it. It's designed to lub inside the cylinder with steam.
Gold Digger is offline   Reply With Quote
Old 08-14-2015, 09:18 AM   #10
Mitch//pa
not getting involved in the what type of oil debate..
it sounds like you have water mixed with the trans oil which will cause it to get milky
ck the rear diff and see how that looks.... maybe the car was parked on a hill and it traveled into the trans
Old 08-14-2015, 09:32 AM   #11
tuneman
tuneman's Avatar
Smile Re: Transmission Oil Cloudy. Synthetic or regular
Just wondering, lol.
tuneman is offline   Reply With Quote
Old 08-14-2015, 10:34 AM   #12
BILL WILLIAMSON
Seriously, in the old days, without electricity or battery chargers, folks would try to park backward, on a "hill", for a sure start. Mrs Bell rarely drove her '39 Plymouth, if it didn't start on her "hill", she'd coast out on the road, look PATHETIC, & wait for someone to come along & push her!
Bill W.
Old 08-14-2015, 02:09 PM   #13
RobertB
RobertB's Avatar
Talking Re: Transmission Oil Cloudy
Bill W.
Yeah....I put it on the doorknob to keep the wife from waking me up...
RobertB
Santa Teresa, NM
RobertB is offline   Reply With Quote
Old 08-14-2015, 02:18 PM   #14
modela4shane
Milky condition could also be the assembly lube or assembly grease used during the rebuild that is now mixing with the gear oil.
modela4shane is offline   Reply With Quote
Old 08-14-2015, 02:39 PM   #15
oliverguy
Good idea. Ask your mechanic if he used lubriplate or some other white assembly grease. Or drain it out and send it off to be anaylized. That will really tell you what's in it.
I like when someone just mentions some type of oil it throws some people into tantrum on this forum. If nobody wanted 600W any more, you wouldn't see it for sale at every antique car meet.
oliverguy is offline   Reply With Quote
Old 08-14-2015, 02:45 PM   #16
Patrick L.
Patrick L.'s Avatar
Sounds like foam to me too. Maybe try a different brand of oil from 140 to 250 weight. There isn't that much difference in the two.
