I have a 1949 ford pickup with the original flathead 6 engine. After driving about 1.5 miles, my temperature gauge goes to 3/4 of the way up. I have installed a new sending unit. When the gauge was 3/4 up, i cut the engine off and carefully took the radiator cap off. When i took the cap off, it didn't boil over and there was no steam coming out. I checked the water temperature and it was 160 degrees. I let the engine run some more and the gauge went up to 7/8 of the way up and the water temperature went up to 170 degrees. Is there some kind of adjustment on the gauge? the truck has been converted to 12V and currently does not have a thermostat. Any help would be appreciated.
Thanks, Brandon |
What is connected to the gauge, 6v or 12v? What type of replacement sender, NOS Ford or a modern one?
Now that you know what temperature it is at a given position on the gage keep that in mind and drive it. Look at the original gage as just a guide that does not give actual temperature readings.
If you want actual readings install a mechanical gage to operate in conjunction with the original.
Thanks, if there isnt an easy fix then ill just know what position is too high. The sender is NOS sender and the gauge has 12v connected to it.
The gauge and sender are made to work with 6v and will not work correctly with 12v. Need a voltage reducer on the gauges.
The sign of a good craftsman is how well they cover up their mistakes. |
My original sending units work well with my new old stock gauge on 12 volt w/o voltage reducer. I believe the circuitry uses the current flow controlled by the varying sender resistance to mimic the gauge resistance so it works with 6 or 12 volt. It really is a clever design. Same with the fuel gauge.
#8 | |
![]() Quote:
'52 F-1, EAB flathead |
6 v positive ground vs 12 v neg ground . I have done the same early and the gauge reading was scary until I added a resister .
"I can't cry as long as I know the Lord has risen " |
Fit a voltage reducer to the gas and temp gauges, you need to for them to work correctly. Simple job.
Martin. |
As Ross stated, the early Ford senders/gauges do not work on a resistance, it is a current pulse system.
I run a 195 degree stat in my 50 Coupe with 226 6. It runs best when hot at 195. On occasion it will go to over 110 but never has let me down for 30,000+ miles. Taking temps with an infrared gun, the hottest its been was 110.
Don't believe your gauge markings. Make sure you do not overfill the rad. Fill it and let it puke it out-it knows where it wants to be. |
