Just wondering about the mix of hubcaps I have on my Canadian built, Australian assembled phaeton. Everything from the running boards up is dated June 1928 (on the firewall). The previous owner jacked the car up and rolled a complete running USA-import '28-29 chassis (a rodder's cast-off) under it, mainly to take advantage of the updated brake system and a stronger engine.
So, the four 28-29 (US) wheels on the ground have hubcaps with a flatter profile and the Ford script with a "short" F (top row in photo). The spare (Canadian) wheel that came with the car was of the E28 (AR) type, and has a hubcap with a more dome shaped profile and the Ford script has a long flowing F that extends over the other letters (bottom row in photo). Do these hubcaps accurately represent differences between Canadan and US hubcaps produced in 28-29, or the design change that occurred over the 1928 - 29 period? Or are they all perhaps after-market repros made with varying degrees of authenticity? ![]() I'm in the process of painting a later spare wheel to match the four on the road, and will have to remove the hubcap from the old spare and install it on the new spare. Is the removal/replacement process just a matter of bending each of the little tabs accessed from the back of the wheel? Are there any tricks I should know about? Last edited by Hoogah; 04-07-2015 at 09:21 AM. |
It sure would help if you cleaned them up some. Also, clearer, larger photos.
What I see of the 4 photos is #1, I think is a repop. Number #4 (if the photo in #3 is the mate), looks like the rarest of the 28-29 hub caps. |
I say that the caps you have with the short top on the "F" are repops. How about the earlier cap? Is it simply a Ford script with nothing else?
#4 | |
![]() Quote:
Sorry about the photos. I won't get back to the car until the weekend to rectify the "clean them up" situation ![]() Photos 1 & 2 are of the same US 28-29 cap. Photos 3 & 4 are of the original Canadian E28 cap. |
RG&JS page 22-3, 4, 5 revised 2011
HUBCAPS The early 1928 hub cap was used through June 1928. The caps were marked "Ford" (script), "Made in U.S.A.", with a manufacturer's trademark ("R" "w" a star or plain) beneath the "S" in U.S.A. The shapes (silhouettes) of the preceding hub caps varied. June through August 1928 hub caps, similar in shape, had a Ford script with no "Made in U.S.A." marking. From September 1928 through 1929, hub caps had Ford script only and a different profile. Prior to April 1929, all hub caps were bright nickel plated. Thereafter, nickel and chrome plated hub caps were used through the end of 1929. There were many silhouette shapes of 1928-29 hub caps. Judge the quality of plating and/or buffing as well as the condition and overall shape. All 1928-29 hub caps were plated steel. The 1930-31 hub caps were stainless steel or stainless clad. They are distinguished by a continuously smooth outer edge surface (with no lip or crimping marks at the edge) and a recessed center circle that was convex with a Ford script. One manufacturer, Noblitt-Sparks, made Ford script centers which were nearly flat rather than domed. Hub caps in early 1930 were stainless steel with no reinforcement liner. These hub caps had twenty attachment tabs that were part of the hub cap shell. In March 1930, a partial steel liner was added, but the outward appearance was unchanged. The stainless steel made a rounded blunt edge where the hub cap contacted the hub. The third type, introduced in late 1930, had a full metal liner with ten attachment tabs. The stainless steel skin was thin and made a very sharp bend where it contacted the hub. In 1930-31, there were slight variations in the center recess and Ford script as molds were replaced due to use (approximately every 10,000 stampings). In 1931 some hub caps were produced with chrome plated brass shells. These were for service only and are not acceptable for judging. All hub caps, including the spare, must match. Check all hub caps for tightness against the wheel. Hubcaps numbered from left to right Hubcap 1 - Ford Script and lettering on hub cap used from the beginning of production through June 1928. Trademarks in the lowest portion varied, but should match Hubcap 2 - Ford Script on hub cap used from June 1928 through August 1928 Hubcap 3 - Typical Ford Script on hub cap used from September 1928 through 1929 and 1930 commercial vehicles with 21" wheels. Note: there was a large variety of scripts. Hubcap 4 - Ford Script on early and mid 1930 hub cap Hubcap 5 - Ford Script on late 1930 to end of production hub cap with "E" trademark stamped inside Hubcap 6 -Ford Script on late 1930 to end of production hub cap with "NS" trademark stamped inside Hubcap 7 -Ford Script on late 1930 to end of production hub cap with "R" trademark stamped inside
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
interim cap. I think Gary needs to look at the new photo,...I'm sure he's seen one in person.. |
Thanks for posting more pictures. The US caps are definitely reproductions. The Ford script interim cap is definitely a Canadian cap. It is hard to see but there is a star centered below the Ford script, making it a Canadian cap. I have one of these here. The US interim caps did not have the star below the script. The interim caps are actually a very rare item. I have only found a couple of them in all of my years of swap meet scrounging. They are both on the June '28 Phaeton of my late friend Dave Lopes.
So there is! Thanks, Gary!!
Just as well I left all that dirt and rust on there to get stuck in the corners or it would have gone un-noticed! ![]() I wish I'd known this when I bought the car, as I reckon I could have snagged the other four that stayed put, on the original rolling chassis that was wheeled out from under this car and re-assigned! I'm content that I know what I've got now, thanks to all for your expertise and willingness to help! The only unanswered (boring) question I have is re the removal and replacement process - is it just a matter of unbending the little tabs to remove and re-bending to replace? |
The 1st one is a repro ; second one with large script looks the AR wheel hubcap. It probably has no star as Canadian.
Be careful bending the tabs as they break off easily. I prise mine off & bang them back on & try not to touch the tabs. |
