Old 03-27-2015, 06:48 AM   #1
Redbird
Redbird's Avatar
Default Bumper clamp color
What color blue paint and where do you get it for the bumper clamps? Do you just mask off and paint?
Redbird is offline   Reply With Quote
Old 03-27-2015, 06:52 AM   #2
davehc
davehc's Avatar
Default Re: Bumper clamp color
Redbird , I went to Hobby Lobby , in the model car ect. section , and found a small bottle of Ford blue that worked fine for mine , and just used a small artist brush to apply .
davehc is offline   Reply With Quote
Old 03-27-2015, 06:58 AM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
I bought some from Bratton's about 20 years ago and it worked well with a small brush. 6 months later I wanted to use some more, but found it was all dried up. Once you open the bottle it's best to use it up or give it away.
Old 03-27-2015, 07:28 AM   #4
springerpete
springerpete's Avatar
What is your method of prepping the surface before you paint ? Some are chrome, some stainless and some other metals.
springerpete is offline   Reply With Quote
Old 03-27-2015, 08:09 AM   #5
wrndln
Chrome and SS seem to hold the paint OK. If sometime in the future, the paint starts coming off, use some lacquer thinner or paint remover, remove the old paint and paint it again. However, I doubt the paint will come off the clamp.
Rusty Nelson
Old 03-27-2015, 08:29 AM   #6
whirnot
whirnot's Avatar
I just buy a bottle of Bumper clamp paint from Berts.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
1931 Coupe
2 Smith Motor Compressors
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 03-27-2015, 08:57 AM   #7
Ray64
Ray64's Avatar
I just use the STICKERS from the parts houses
Ray64 is offline   Reply With Quote
Old 03-27-2015, 09:42 AM   #8
John Duden
John Duden's Avatar
I used rust oleum royal blue brush in style. I took a scotch bright and scuffed the inside first then took a paint brush and put a lot of paint in it. I did not pull the paint with the brush but pushed it to the edges. A good amount of paint needs to be added so after you push it around it will flow back together get rid of the brush strokes. Let it dry for about a week or else the paint will flow down when mounted
John Duden is offline   Reply With Quote
Old 03-27-2015, 11:07 AM   #9
burner31
burner31's Avatar
I do not worry about judging or points, so I use blue...simple
Keith
Shawnee OK
'31 SW 160-B
Old 03-27-2015, 07:20 PM   #10
WestCoast
its called Harding Bumper Clamp Blue, I use a brush and don't worry about some paint getting outside, I take a rag and wrap it around my finger and then dip it in paint thinner and simply wipe off the excess, put it on thick so the paint will fill In any pits or scratches and flow out smooth
WestCoast is offline   Reply With Quote
Old 03-28-2015, 12:04 AM   #11
Mike V. Florida
Mike V. Florida's Avatar
FYI originally there was a mask with holes cut out tin the shape of the inside. Then they were sprayed.
