Old 02-22-2015, 10:18 AM   #1
oldbike99
oldbike99's Avatar
Default Direction of splash pan bolts
Do the nuts go on the top or the bottom? Thanks in advance.
Paul
oldbike99 is offline   Reply With Quote
Old 02-22-2015, 10:31 AM   #2
Mitch//pa
Default Re: Direction of splash pan bolts
bottom
Old 02-22-2015, 10:24 PM   #3
glenn in camino
glenn in camino's Avatar
Square nuts on the bottom with cotter pins.
Old 02-22-2015, 11:34 PM   #4
Mike V. Florida
Mike V. Florida's Avatar
Until mid 1929 when the cotter pins were dropped.
Old 02-23-2015, 03:31 AM   #5
fiddlybits
fiddlybits's Avatar
I will always install a bolt such that gravity will keep it in place of the nut is lost. I have fount the only time this to be incorrect is when there is inadequate clearance to insert the bolt in that orientation.
fiddlybits is offline   Reply With Quote
Old 02-23-2015, 03:40 AM   #6
JEC
Nut's to the pilot.
JEC is offline   Reply With Quote
Old 02-23-2015, 08:47 AM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
The two bottom radiator mounting bolts are the only ones I can think of where the nuts are on top, and that sure made it harder to install and remove the cotter pins.
Old 02-23-2015, 01:09 PM   #8
briphaeton
I picked these up many years ago and was told they also used spring as shown in photo.
Explains the reason that both nut and bolts were drilled.
Brian
briphaeton is offline   Reply With Quote
Old 02-23-2015, 04:13 PM   #9
kevinmac/toledo
makes sense. keeping down rattles maybe....
kevinmac/toledo is offline   Reply With Quote
Old 02-23-2015, 04:46 PM   #10
fiddlybits
fiddlybits's Avatar
Oh, sure, remind me of all the "fun" of those two little beauties. (how long are your arms?)
Old 02-23-2015, 10:47 PM   #11
Gary Karr
Gary Karr's Avatar
They look like a good idea but unfortunately they are not originals. The hex bolts had a hole for a cotter but the 1/2" square nuts did not have holes plus they did not use springs.
Gary Karr is offline   Reply With Quote
Old 02-24-2015, 01:42 PM   #12
Charles Reese
Charles Reese's Avatar
the thread seems to have moved from engine pan to radiator mounting bolts ... attached see (L) original engine pan bolt (early), no nut. (R) original rad mount bolt/nut/spring (early short version)
Charles Reese is offline   Reply With Quote
