Old 09-22-2014, 07:20 PM   #1
ifightfire
ifightfire's Avatar
Default Clutch pressure plate help
im installing the pressure plate on my 1930 model A engine. freshly turned fly wheel , new clutch disk. After tightening the pressure plate I measured the finger to top of pressure plate. the book says it should be 5/8''... i am measuring 1 and 3/8 inch. what am i doing wrong.
ifightfire is offline   Reply With Quote
Old 09-22-2014, 07:55 PM   #2
700rpm
700rpm's Avatar
Default Re: Clutch pressure plate help
You probably aren't doing anything wrong. You just need to adjust the fingers.
Ray Horton, Portland, OR
Old 09-22-2014, 08:10 PM   #3
ifightfire
ifightfire's Avatar
that was very interesting but i dont under stand what is ment by the "cover"
"adjust the nut until you get a distance of 11/16", measured from the top face of the rear of the lever, down onto the cover.
Old 09-22-2014, 11:23 PM   #4
jw hash
jw hash's Avatar
the cover is the outer part of the pressure plate. lay a straight edge across est the outer surface of the pressure plate and measure down from there to the arm where the throw out bearing makes contact. that should be 5/8 or 11/16
jw hash is online now   Reply With Quote
Old 09-23-2014, 08:01 AM   #5
Dave in MN
Dave in MN's Avatar
Is it possible you have the disk installed backwards?
Dave in MN is offline   Reply With Quote
Old 09-23-2014, 09:21 AM   #6
Richard Lorenz
I believe that the 5/8 distance came from one of the popular repair manuals. Someone else found that the Ford spec was actually 3/4 inch. A little more wouldn't hurt.
Richard Lorenz is offline   Reply With Quote
Old 09-25-2014, 08:56 AM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
A piece of aluminum channel threaded for a bolt and lock nut makes adjusting the fingers easy. I set the bolt for a depth of 5/8" to 11/16", lock the nut and then use a thin feeler, such as .010" to feel each arm for a slight drag when it's properly adjusted.
