Old 09-26-2014, 07:01 PM   #1
Bill S
Default Gear oil
I want to use 140 gear oil. The major company's do not have straight 140.
O'reilly, Pep Boys and Walmart do in their brand name. Anyone have opinion of how good the brand name ones are?
Bill S is offline   Reply With Quote
Old 09-27-2014, 06:32 AM   #2
Terry,OH
Terry,OH's Avatar
Default Re: Gear oil
NAPA sells Sta-Lube SL-24238 Gal container GL-4
Old 09-27-2014, 06:54 AM   #3
sortkaffekop
sortkaffekop's Avatar
I tried 140. Went back to 90. (Regardless name)
sortkaffekop is offline   Reply With Quote
Old 09-27-2014, 08:41 AM   #4
Bill S
sortaffekop. Why did you go back to 90? I will be putting the 140 in the rear axle.
Old 09-27-2014, 10:50 AM   #5
rotorwrench
rotorwrench's Avatar
Straight grade lubes are getting harder to source. Restoration Supply Co. carries the Lubriplate SPO series straight grade lubricants as well as Penrite oils. Lubriplate products can be purchased from many bearing supply companies as well.
Sta-Lube is still the easiest option since it is carried by NAPA and other parts supply companies.
Old 09-27-2014, 01:11 PM   #6
supereal
supereal's Avatar
Many go to 140 to lessen leakage. In a worn transmission, it sometimes helps shifting by slowing down the cluster gear. With few exceptions, today's oil and greases are light years ahead of the kind available when the vehicles were new.
supereal is offline   Reply With Quote
Old 09-27-2014, 08:03 PM   #7
quickchange34
quickchange34's Avatar
Sta-Lube 140 is easy to come by and it works,
quickchange34 is offline   Reply With Quote
Old 09-27-2014, 10:47 PM   #8
Kahuna
Kahuna's Avatar
I use 80-90 from NAPA in trans, O/D and rear axle and steering box. Make things easy and no leaks
Kahuna is offline   Reply With Quote
