Old 06-23-2014, 02:43 PM   #1
j.threadgill
j.threadgill's Avatar
Default 1938 Ford 4 Door Convertible
I am trying to fix an issue with Headlights and taillights not working. I do not see a switch for the headlights. It has a switch that turn on the fog Lamps, which work. There is a small two position toggle switch on the bottom of the dash on the left side of the steering column which doesn't seem to do anything. Also has a floor switch which looks like a dimmer switch. Any good sites to go to with diagrams and the like and any suggestions. Also is there more than one fuse bar location? Everything I have found says there is only one under the dash on 1938 Ford.
j.threadgill is offline   Reply With Quote
