Old 03-27-2014, 12:17 PM   #1
M2M
M2M's Avatar
Default What carby setup do we have here?
I came across this photo. Does anyone know what carb and manifold we have here? There doesn't seem to be a fuel pump. How does this compare to the often used Weber carb setup?
M2M is offline   Reply With Quote
Old 03-27-2014, 12:40 PM   #2
Purdy Swoft
Purdy Swoft's Avatar
Default Re: What carby setup do we have here?
It appears to be a V8 style carb possibly model 94-59-48. It doesn't really compare to a Weber. They are both two barrel carbs but the Weber is a progressive two barrel that has the ability to cut in like a four barrel.
Old 03-27-2014, 01:25 PM   #3
PC/SR
Its a Holley (or Ford which manufactured some of the same carbs), or, possibly a Chandler Grove which made the 1938 models, all used on the flathead V8s. The venturi size is embossed on the rear, could be "81" or "94". Or, unlikely, "1" or "1 1/16" which were used on the 1954 and 1955-57 OHV V8s. An "81" is the Holley Model 92, a replacement for the Stromberg 81. The "94" replaced the Stromberg 97. The Model # or letter identification should be embossed on the fuel bowl side that is not visible in the photo. That will give a better idea the years it was used.
PC/SR is offline   Reply With Quote
Old 03-28-2014, 04:58 PM   #4
Mikeinnj
Mikeinnj's Avatar
Stromberg 97's are still being made...http://www.stromberg-97.com/carburet...97.asp#prodfrm
Mikeinnj is offline   Reply With Quote
Old 03-27-2014, 11:34 PM   #5
garyaodell
The manifold in a Scolded Dog, this looks like my set up and from the choke leakage I'd say the carb is a 94 8ba made from 1949 to about 1953. I use a fuel pump.
garyaodell is offline   Reply With Quote
Old 03-28-2014, 01:25 PM   #6
Hitchhiker
Could have a fuel pump behind the firewall to give the illusion of no pump.
Matt in Seattle
Hitchhiker is offline   Reply With Quote
Old 03-28-2014, 05:21 PM   #7
jkeesey
jkeesey's Avatar
Im surprised people actually run choke linkages on these setups. Ive never needed one on any of mine.
jkeesey is offline   Reply With Quote
