Old 03-02-2014, 06:14 AM   #1
big job
big job's Avatar
Default I had a dream ?
I had a dream of a T with a 8N engine. Really not that way out if they
can put V8s and V12 Lincolns in tractors why not. Easy part machining
tractor crank to the planetary, machining hogs head. I think the hard
part would be fabbing the T pan so it would contain its own oil. Although
it was a dream, but my Ford tractor is whisper quiet, run her hard all
day no viabrations just sweet. If that fellow on utube can cut a T engine
in half with a common hack saw and run it anything can be done!
I have all machinery necessary for this kind of operation, if I could find a
junk 8N and planetary.......
big job is offline   Reply With Quote
Old 03-03-2014, 01:38 PM   #2
Willie in Houston
Willie in Houston's Avatar
Default Re: I had a dream ?
That dream may actually be a "Night Mare", but I have seen more than one T with V8 engines in them. Good luck, I will stay with getting a little more HP out of a standard T engine.
Willie in Houston is offline   Reply With Quote
Old 03-03-2014, 06:22 PM   #3
yachtsmanbill
yachtsmanbill's Avatar
You can do anything if you set yer mind to it. ws
" Warning; the following contains content that the anal retentive may find offensive - please skip on to the next posting!"
yachtsmanbill is offline   Reply With Quote
