Old 11-29-2013, 04:38 PM   #1
Cape Codder
Cape Codder's Avatar
Default Brake Adjustment
I'm trying to get the very most from my mechanical brakes.
The "Model A Ford Service Bulletins" start in January which I'm assuming is in the year of 1928. Is that correct? If so on pag e 259 which is June, it states that all break rods have been changed from adjustable to nonadjustable type. So if I have read THAT correctly any vehicle after June 1928 should have NON adjustable rods on? I must say that all I have ever seen are the adjustable type rods.
On to the second part of my post which pertains to the length of the rods and the Service Bulletins state "the length of the rod should be
51 7/16" to 51 1/2" but the illustration shows centerto center with the same dimensions. Would this not be two different dimensions? If the length is stated as such would that not be longer than center to center?
Thanks to all for your time.
Cape Codder is offline   Reply With Quote
Old 11-29-2013, 04:49 PM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: Brake Adjustment
It is my understanding [without looking] that some very early 'A's' had non-adjustable brake rods. I don't think that lasted too long. When adjusting I start with the rods being 51.5" center to center.
Old 11-29-2013, 04:53 PM   #3
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Those were only a short run design change before they went to the type brake rod you are accustomed to seeing.
Do not get overly concerned with the eye-to-eye length at this point since your system is "used" but set the rods up where they are all equal. From there, make sure the actuator arms are in the forward position, and then see how the clevis pins align to the service brake cross-shaft. The biggest key is you do not want excessive "lost motion" in the system, and you need the actuator arms in the position where the maximum amount of leverage is made when they are in full activation.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 11-29-2013, 08:10 PM   #4
Marco Tahtaras
Marco Tahtaras's Avatar
Anything with functional holes is measured center to center of the holes so that is in fact the functional "length" from an engineering standpoint. This is similar to screws and bolts where "length" is from the surface of the item which the head would clamp, to the threaded end. This should always be the case unless something says "overall length".
As Brent said, the solid rods were only used for a short time. They were only used with the '28 equalizing system which was used until late '28. In fact, fixed length rods will ONLY work the equalizer system as the system functions by taking up any slack going to each wheel and then applying equal or even mechanical pressure to each of the four wheels. It is NOT possible to have all the rods the same exact length with the solid brake cross shaft AND have properly functioning brakes.
http://www.abarnyard.com/
Marco Tahtaras is offline   Reply With Quote
Old 11-29-2013, 08:59 PM   #5
ctvpa
ctvpa's Avatar
There is a great video "How to stop on a dime with a Model A" it takes you through all of the tricks. If you want to borrow it, PM me and I will loan it to you.
However, that being said, I did all the recommendations in the video and my breaks were 60% improved. Then I went to the Flathead Teds http://www.flatheadted.com/ and got the deluxe set front and rear, and now I can leave skid marks with all 4 tires. Snyders carries his product, Mike's a-fordable has a knockoff, but when I bought mine it was cheaper to buy them direct from Ted's website, then came in about 14 days.
ctvpa is offline   Reply With Quote
Old 11-29-2013, 09:30 PM   #6
Cape Codder
So what you guys are saying is that our beloved Model A Service Bulletins is wrong. It starts out by saying"[I]BRAKE RODS HAVE BEEN REDESIGNED MAKING THEM INTO A SOLID NONADJUSTABLE TYPE.
To me that means the book is telling us that they were adjustable and then went to solid nonadjustable in June. Sooooooo………is our Model A Bible wrong?
Thanks for your time and understanding but I'm just trying to understand "the Book"
Old 11-29-2013, 09:38 PM   #7
QGolden
QGolden's Avatar
I am on the road and do not have my service bulletins with me, but I think if you continue to search you will find the switch to the later rods that '29-'31 A's have.
It's not what people think they know that will hurt them, it is what they think they know that aint so! -Mark Twain.
It is the very things that we think we know, that keep us from learning what we should know.- Unknown
QGolden is offline   Reply With Quote
Old 11-29-2013, 11:11 PM   #8
Tom Wesenberg
Tom Wesenberg's Avatar
The SERVICE BULLETINS are correct. The Model A started with adjustable brake rods, then when the new brake system (with the seperate parking brake lining) came out about mid 1928 Ford went to the non-adjustable rods. Then when the new one piece brake cross shaft came out in November 1928, Ford went back to the adjustable rods. The non adjustable rods are somewhat hard to find, but I finally found mine when I went to Bert's several years ago.
Old 11-30-2013, 12:40 AM   #9
RonC
RonC's Avatar
As mentioned Ford went back to adjustable rods. Not every change is mentioned in the bulletins. The Service Bulletins, issued monthly by Ford since 1919 to the branches, were not the only document issued. Ford also issued Service Letters daily. There were also engineering releases and drawings produced for each part. Ford also had training classes, parts books, etc.
RonC is offline   Reply With Quote
Old 11-30-2013, 12:57 AM   #10
Marco Tahtaras
Ok, you lost me. They were correct as we noted/answered following your question. Were you looking for them to note FUTURE, unknown as yet changes on that date? I'm definitely confused!!!
Old 11-30-2013, 02:39 AM   #11
Brentwood Bob
What is the month and year of your car? Bob
Brentwood Bob is online now   Reply With Quote
Old 11-30-2013, 11:58 AM   #12
Cape Codder
Tom - thanks for your excellent explanation. I actually did not read far enough in the Bulletins to find that information.
Brent and Marco - I was thrown off by your reply when you said that they started solid, when in fact they were adjustable at the start, solid and then adjustable to the end as Tom explained.
Thanks again Tom, your reply made me read the Bulletins further.
Brentwood Bob - I have a '31 month unknown.
Marco - On page 82 of the Bulletins it does state"the length of the rod measured from the centerline of both eyes should then be adjusted to not more than 51 7/16" or less than 52 1/2" "as you tried to explain. Sorry I'm not an engineer so I didn't know anything about functional "length".
I want to Thank everyone for their input and am now much better versed on the brake system of the Model A and the changes that transpired.
Thanks again.
Old 11-30-2013, 12:22 PM   #13
Patrick L.
Patrick L.'s Avatar
There tends to be 2 methods for adjustment.
I set each wheel adjustment as I want it, then use a brake adjusting board and adjust the length of each rod for the amount of drag I want.
Old 11-30-2013, 10:56 PM   #14
ericr
ericr's Avatar
I'd like to see an explanation of why the Service Bulletins, which often go into great detail about repairs, give no mention to brake restoration aspects that we read about in the Barn such as lubing the parts, centering the brake shoes, etc.
ericr is offline   Reply With Quote
Old 11-30-2013, 11:07 PM   #15
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Good luck with the board "trick", you'll NEED it!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 11-30-2013, 11:08 PM   #16
Tom Wesenberg
The SERVICE BULLETINS mention production changes or repairs that should be made to recently built parts. They don't and couldn't at the time mention repairs due to long term wear.
Old 11-30-2013, 11:30 PM   #17
Bob C
The March, April, May 1933 SERVICE BULLETIN says two new gauges, AB-117 and AB-118, have been designed for checking the concentricity of the brake assembly.
Old 12-01-2013, 12:56 AM   #18
BILL WILLIAMSON
The Service Bulletin Book would be this, l-----------------------------------------------------------------------------------------------------------------------------l, thick, if it was re-written for 80 SOMETHING year old cars!!!!! Bill W.
Old 12-01-2013, 08:05 AM   #19
BRENT in 10-uh-C
Thanks again.
I honestly don't think I said that!!??
BRENT in 10-uh-C
