09-06-2013, 03:06 PM | #1 |
continuation of Betsy's thread-stuck engine
didn't want to hijack Betsy's thread....
pulled the head on my engine and 3rd cylinder will not let atf through, so tapping it with a 2x4 every other day my question is-pulled the valve cover off and water rolled out-6 of the 8 valves are stuck down in the block-what methods do you folks use to get them up and moving? a friend suggested PB Blaster on top and underneath, but am thinking someone here has an ingenious method or 2 for freeing them.... thx ahead of time. |
09-06-2013, 05:59 PM | #2 |
Re: continuation of Betsy's thread-stuck engine
Remove the manifolds & spray Liquid Wrench on upper & lower ends of valve stems.Don't use WD 40 as it doesn't work very well.You may have to respray it a few times over the next few days.Take an old screwdriver & grind it down thinner on the end & try lightly tapping it between the lifter & valve.If a valve moves slightly,then tap it back down with an angled rod thru the plug hole.If to tight,you may have to pull the head to get a straight hit on the valve.
09-06-2013, 06:42 PM | #3 |
the best penetrating oil you can use is one you make your self, a 50-50 mix of auto trans oil and acetone, works where others fail, spray on valve stems and lifters and let set for a day
09-06-2013, 07:16 PM | #4 |
Claude heated the valve stems through the ports & cooled them with WD-40, several times to help free them up. Bill W.
09-06-2013, 08:20 PM | #5 |
Bill, you ole reprobate, you going to the auburn swap meet the 15th of this month?
09-06-2013, 11:48 PM | #6 |
am vacuuming out tons of rust in the ports. |
09-06-2013, 11:54 PM | #7 |
09-07-2013, 01:42 PM | #8 |
altho its put on by the chevy club there are lots of ford a and t stufff there, mostly stuff from guys garage thar they have left over or didnt use, its up in the parking lot at the fair ground, usually a good meet
09-07-2013, 07:52 PM | #9 |
Kroil is the best penetrating oil I have ever tried. Kroil and patience works every time.
09-07-2013, 08:45 PM | #10 |
Thanks Glenn, was out there playing today- the patience part is tough
was able to get 4 of the 8 lifters turning, by putting a very small pair of vice grips on them and swiveling them back and forth with PB Blaster was going to buy the acetone, but almost 20. bucks a gallon, thought I'ld start with the PB the valves are still pretty locked up and this could take awhile-cylinder #3 is still not running clear of the atf and gas I mixed 50/50 hoping when that cylinder clears, may get a little movement from the crank.... |
09-08-2013, 10:51 AM | #11 |
7 valves are up-thx to the ground down screw driver and KB
1 to go and 2 lifters still frozen along with cylinder #3 going to set a floor jack under the crank handle with a little pressure overnight.... thx for all of the advise-much appreciated. |
09-08-2013, 06:42 PM | #12 |
09-08-2013, 06:59 PM | #13 |
LOL chuck your right, a car swap meet in auburn calif, a lot of used parts for a lot of different cas
