Old 06-07-2013, 05:39 PM   #1
johnsor
Default Grease Fittings
My 31 "A" has the old style straight grease fittings with no hex on them for removing. With no hex, how do I remove them? Are they threaded in or just pressed in?
johnsor is offline   Reply With Quote
Old 06-07-2013, 05:51 PM   #2
ford3
Default Re: Grease Fittings
pressed in
ford3 is offline   Reply With Quote
Old 06-07-2013, 05:58 PM   #3
Mitch//pa
I use a real good small pair of channel locks it grips them good
Grab them at the base but leave a little space so you don't mar the surface of the part
Just changed all mine out after having everything powdercoated and didn't make a scratch on anything.
Old 06-07-2013, 06:12 PM   #4
H. L. Chauvin
How to remove? Remove carefully.
Use a small cold chisel & a small hammer. (And/or a pair of pliers or better yet, a Farrier Nipper used to trim horse hooves -- everybody had farrier nippers in the 1930's).
Place the cold chisel point at the joint between the grease fitting & the adjacent steel surface & tap lightly on all sides to try to wedge the chisel point between the fitting & adjacent surface; i.e., to widen the distance between these two surfaces.
After the fitting moves slightly, about 1/16", place chisel at slight angle to drive fitting out of hole.
One can try rotating the fitting with a pliers & pulling outwards also.
Others may have other methods.
H. L. Chauvin is offline   Reply With Quote
Old 06-08-2013, 02:09 PM   #5
QGolden
QGolden's Avatar
If you don't plan to reuse them, Vise Grips, twist and wobble them out.
It's not what people think they know that will hurt them, it is what they think they know that aint so! -Mark Twain.
It is the very things that we think we know, that keep us from learning what we should know.- Unknown
QGolden is offline   Reply With Quote
Old 06-08-2013, 02:42 PM   #6
marc hildebrant
marc hildebrant's Avatar
After the original fittings are out, do the holes need to be tapped for the modern fittings ?
Marc
marc hildebrant is offline   Reply With Quote
Old 06-08-2013, 02:57 PM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
Marc
I think the Model A parts house have both the screw in and the drive in fittings in modern style.
Old 06-08-2013, 04:05 PM   #8
Richard/Ca
Richard/Ca's Avatar
Good time to ask! (I hope) Do most restorers pro or amateur replace the original fittings with the modern fittings. Sorry to hi-jack your thread but it seem like a good opportunity. Richard/Ca
Richard/Ca is offline   Reply With Quote
Old 06-08-2013, 11:39 PM   #9
SeaSlugs
SeaSlugs's Avatar
I was wondering this too. I understand how the origional straight style sealed with the greasegun but i dont understand how the origional 45* style sealed... its just a hex cap with a straight small tube sticking out thats supposed to go on the grease gun.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 06-09-2013, 12:04 AM   #10
Tom Wesenberg
I like the original fittings and use my original tool kit grease gun as well as a modern gun with the special adaptor. They both work great and seal without loss of grease better than the modern fittings.
Old 06-08-2013, 04:13 PM   #11
QGolden
QGolden's Avatar
I bought the threaded kit for modern fittings.
Old 06-08-2013, 09:38 PM   #12
H. L. Chauvin
I re-install new drive in fittings after removal of old ones & cleaning openings.
Best to get special drive-in tool to drive them in -- works great.
Old 06-09-2013, 02:25 AM   #13
CarlG
CarlG's Avatar
From Snyder's catalog:
Grease Fitting Set
  • A complete set of grease fittings for the chassis. Available in original style or modern zerk style. Kit contains press-in as well as threaded style. 1928-31. 32 pieces per kit, modern style above, original below. U.S.A.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 06-09-2013, 07:08 AM   #14
Banky
If you get the press in style spend the few extra bucks for the tool to bang them in. Another lesson learned the hard way, seems to be my motto!
Banky is offline   Reply With Quote
Old 06-19-2013, 11:38 PM   #15
MartyAndrew
MartyAndrew's Avatar
Hi all. It seems the right people are on this thread so I'll add my question to the fray.
I'm about to replace my spring shackles on my '29 and I have to choose grease fitting type. The whole car has the old style. Is there any advantage or reason to go with the modern style or should I keep things consistent?
Marty
MartyAndrew is offline   Reply With Quote
Old 06-20-2013, 04:18 AM   #16
Tom Wesenberg
No, keep the original fittings.
I find original fittings never leak grease to the side, like the modern fittings sometimes do. Beside that, they are the ones that belong on the car.
Old 06-20-2013, 06:39 AM   #17
Mitch//pa
i also would keep the authentic fittings
Old 06-20-2013, 06:44 AM   #18
QGolden
QGolden's Avatar
Just be sure they are clean and the grease actually goes through them. Old hard grease, dirt and paint could have closed them up.
Old 06-20-2013, 08:34 AM   #19
MartyAndrew
Great tips, thanks. I'll go with authentic fittings.
Old 06-20-2013, 08:40 AM   #20
Mitch//pa
if your not using the original style grease gun, get the little adapter the jobbers sell to go on the modern gun works good.
