Old 04-30-2013, 03:51 PM   #1
sconnors
sconnors's Avatar
Default Painted the wheels
Decided to change the wheel color on my '30 CCPU from cream to black. I also painted the wheels with the tires on the rims. I hit the wheels with a wire wheel on a drill, then used a Scotch Brite pad to get all the loose stuff off. I then blew the entire wheel off with a blower, used denatured alcohol to clean them, then primed and painted them. I also found out that placing a nickel in the lug holes is the exact same diameter of the hole so it worked out that I didn't have to worry about paint getting in them. I've attached some pictures of the process and of the vehicle with both the cream and black wheels.
sconnors is offline   Reply With Quote
