Seal up the gas cap and the fuel gauge opening, and screw a ¼" pipe fitting into the fuel outlet. Add 2 lbs of pressure and use a soapy water mix and spray around every place you can think of looking for bubbles.
thanks for the advice I need all the help I can get and what I read here this is the place to get it
What town in the 'Show-Me' state??
Ozark south of springfield
Maybe do the inflating with one of the rubber pointed air chucks. And hold it with your hand. Thus you could let off at any sign of failing, or if your hand gets tired! I have a gas tank that was used on a doodlebug. It has a large "crease" across the top where a cable must have been wrapped and left it's imprint during it's workaday life. I would dearly love to remove that crease - the tank is in very good condition other than that and I expect will still hold gas. I've thought of different ways to remove that crease, including separating the halves and hammering it out from the inside, or possibly nflating the tank to the point where it "bumps" out. But I dare not. Do the arithmetic. 15 psi x 10 inches deep by 30 inches wide - that's a lot of force. And welded according to a submerged arc procedure that today would be considered not to current weld thinking. So instead I'll simply fill the crunch with bondo, and use the tank minus one gallon capacity. No biggie. Joe K
Shudda kept the horse. |
#7 | |
![]() Quote:
What's right about America is that although we have a mess of problems, we have great capacity - intellect and resources - to do some thing about them. - Henry Ford II Last edited by Mike V. Florida; 02-22-2013 at 01:33 AM. |
#8 | |
![]() Quote:
Hmm. This possible. At the very least it would reduce the amount of filler required (thin is better, of course.)
Joe K
Thanks again the reason for the question I inherited a 1930 coup with a one gallon lawn mower gas tank bungee cord to the firewall with no filter to carburetor. I put a new pop lock ,plugs and change the oil and she purrs like a kitten looking her over the head lights have new wires not hooked up to the original wires from the switch(wires cut) many other problems that I am learning about as I go but I enjoy the challenge…..again thanks for all the advice .
