Old 01-08-2013, 10:49 AM   #1
4tford
4tford's Avatar
Default installing head studs.
When installing head studs in the block how tight do you put the studs in the block. I am not talking about torquing the heads, just the stud in the block. Thanks Bill
4tford is offline   Reply With Quote
Old 01-08-2013, 11:26 AM   #2
Ol' Ron
Ol' Ron's Avatar
Default Re: installing head studs.
Just put some sealant on them and snug them up, 10/15 lbs if your torquing. Make sure you remove the first thread use a counter bore in a drill.
Old 01-08-2013, 12:04 PM   #3
4tford
4tford's Avatar
Remove first thread on what Ron??
Old 01-08-2013, 01:14 PM   #4
JWL
Ron is talking about a chamfer at the block face. I use only a 1/32"
The stock Ford studs do get minor tightening into the block, as suggested by Ron. However, non-Ford style studs should only be finger tight.
JWL is offline   Reply With Quote
Old 01-08-2013, 01:37 PM   #5
Pinewood
Pinewood's Avatar
What happens if you don't chamfer the face?
Pinewood is offline   Reply With Quote
Old 01-08-2013, 02:02 PM   #6
V8COOPMAN
V8COOPMAN's Avatar
Part of the thread can be "pulled-up" above the block surface by the stud. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 01-08-2013, 04:47 PM   #7
hardtimes
hardtimes's Avatar
Hey Bill,
I've always been told that not all head studs are open to water jackets. And, that some ARE open , because too much force/torque was applied to the studs upon installation...thereby forcing crack/opening when bottoming. Anyway, the point is, if your block threads/stud holes are properly cleaned ...just hand thread the studs , with lube, till bottoming (I use neverseize to prevent galling/seizing/rusting..chose your own poison).
The object is to get full benefit of all block thread strength. The 'torqueing/clamping' FORCE is applied to the nut...not the stud..IMO.
Old 01-08-2013, 06:28 PM   #8
Ol' Ron
Ol' Ron's Avatar
There are 3 blind holes in the deck. One in the middle and one on each end. These are over the exhaust ports. I forget how many threads are on a stock Ford stud but you only have to have 7-8 threads to take full benefit of a 7/16 stud or bolt. I know of no after market studs that meet these specs. In JWL's book he explains in detail the quality of the deck surface and why proper torquing is so important.
