Old 07-31-2010, 08:14 AM   #1
rfv60
Default scrub-a-dub. cast iron prep
been covered b4 but can't locate info on procedures and products to use for cleaning block/head cast iron parts for painting. appreciate the help. thank you
rfv60 is offline   Reply With Quote
Old 07-31-2010, 12:07 PM   #2
Russ/40
Russ/40's Avatar
Default Re: scrub-a-dub. cast iron prep
Solvent or mineral spirits to get all the grease off. Then, a wire wheel on your die grinder. Then repeat a scrub with solvent and a 3m scotchbrite pad. Soapy scrub, then paint.
