Hi, does anyone have knowledge where I can purchase the installation kit for the original steering wheel?
The car had the 1970's custom wheel on it with an after market kit that I removed and does not match up with the orig wheel... ![]() |
Try www.shoeboxford.com , He should have some good used parts to do it. He specializes in n49-51 Ford cars.
Barry 50 F-1 |
If the aftermarket wheel had an adapter on the original shaft you need to remove the adapter. The original wheel should slip right on to the splined shaft. Unless the shaft has been modified you do not need any extra parts.
#4 | |
![]() Quote:
