Old 10-07-2012, 05:51 AM   #1
A BONED
A BONED's Avatar
Default Banger tapping noise at idle...
I have an intermittant loud metallic type tapping noise from my B model banger mill, tap, tap, tap,......tap,.......tap.
The noise only appears to happen at idle and is not always there, seems to be coming from the timing gear area of the motor. I've taken the timing cover off and run the banger for a short time, the noise is definately coming from the front of the mill, although the aluminium timing gears looks okay. Anyone got any ideas of what it could be?
Gomez.
A BONED is offline   Reply With Quote
Old 10-07-2012, 08:54 AM   #2
Mitch//pa
Default Re: Banger tapping noise at idle...
Originally Posted by fordgarage View Post
What is a banger mill? Really?
Banger = hopped up
Mill= motor
Lol = laughing out loud
Old 10-07-2012, 10:42 AM   #3
Jordan
Jordan's Avatar
Gomez.
Might be a valve
Cowtown A's
Jordan is offline   Reply With Quote
Old 10-07-2012, 10:58 AM   #4
Jerry Huntngton Beach
Sounds like a loose shock support.
Jerry Huntngton Beach is offline   Reply With Quote
Old 10-07-2012, 11:50 AM   #5
Dave in Boise
Dave in Boise's Avatar
wonder if it might be the bearing surfae of the cam loose in the block, or perhaps a lifter telegraphing the noise into where you hear it by the cam gear?
you could remove the cam gear and check the front of the cam for play..
good luck..
- Dave
Dave in Boise is offline   Reply With Quote
Old 10-07-2012, 02:09 PM   #6
Jim Brierley
I had a noise like that, it came and went on a regular basis. It turned out to be a worn lifter bore. I reamed the block (while still in the car) and installed Chrysler tappets which cured the noise. These tappets are 5/8" and have a bigger foot so be sure the foot clears the block at the cam bearings and clears the cam itself. I ground a bit off the block and turned down the lifters some. They are also longer, I replaced the adjusting screws with shorter ones.
Old 10-07-2012, 03:25 PM   #7
Lawrie
Lawrie's Avatar
Try running the engine with the timing pin removed and a bolt screwed in to touch the timing gear,then start the engine and just screw it in a little bit more,This will stop most noises from the gear,
then you will know if it is the gear.
then replace it.
Put the timing pin back after though.
Lawrie
Old 10-07-2012, 04:24 PM   #8
P.S.
Where I'm from,
Banger = Gang member who has committed violent crime.
Mill = Where dad worked.
LOL = When the action has temporarily ceased.
P.S. is offline   Reply With Quote
Old 10-07-2012, 04:58 PM   #9
Mitch//pa
Originally Posted by p.s. View Post
where i'm from,
banger = gang member who has committed violent crime.
Mill = where dad worked.
Lol = when the action has temporarily ceased.
hhheehhe
Old 10-07-2012, 05:11 PM   #10
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Jim B mentioned lifter bores, ...and I agree.
One thing I have always wondered is why someone does not offer an oversize tappet manufactured specifically for the Model-A/B engine. One might think there is not a need, but they actually manufacture them for the Model-T engine in 'standard' bore size ...and also in .015" and .030" oversize. I have them in two of my T engines that make the engine much quieter.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 10-07-2012, 05:54 PM   #11
Benson
Egge Machine has them listed in their catalog, standard and .015 oversize.
VL800 MODEL A ADJ LIFTER SET OF 8 $85.00 .000 .015
VL800.015 ADJUSTABLE VALVE LIFTER SET .015 OVER $77.10
They list Model B too but do not remember if the B lifter heels measure the correct .070 larger than the Model A.
http://www.egge.com/site/?d=48&dt=1&...ke=FORD&rpp=10
Old 10-07-2012, 08:31 PM   #12
A BONED
A BONED's Avatar
fordgarage, the much loved ford flathead 4 cylinder engine has been referred to as a 'banger' since the model T rolled out of Detroit back in 1908.
Similarly, the combusion engine has been referred to as a 'mill' since we began to burn gas and turn wheels. These are not just terms 'Hot Rodders' use, they are endearing terms which have been used forever and ever. Referring to people that use these those terms as yo-yos reflects poorly on your good self.
Now lets please get back to why we are here, and that is to provide much needed tech support for what we love most of all, early Fords!
Gomez.
Old 10-07-2012, 08:37 PM   #13
PC/SR
Snyders also has the oversize lifters.
PC/SR is offline   Reply With Quote
Old 10-07-2012, 08:53 PM   #14
1crosscut
1crosscut's Avatar
Interesting. Just to satisfy my curiosity I did a site search and came up with 11 pages with the reference to "banger".
1crosscut is offline   Reply With Quote
Old 10-08-2012, 02:36 AM   #15
dumb person
dumb person's Avatar
i will watch this thread because i want to track knocking noises in engines but... You have to understand that professionals are good to listen to when talking about engines but their opinion of other people are often less important, hard to take them seriously when they think everyone has a lathe & milling machine in their bedroom.
While working on a fuel delivery issue on a survivor car that had only ever had a valve grind and oil pan cleaning a top notch engine builder who happened to be nearby told me i installed the camshaft 90 degrees out when i had rebuilt the engine. Really? i can rebuild engines in my sleep and not even notice? Cool i never knew that, what an awesome skill. Explained to him twice it had never been rebuild but did he listen? No... because he knows everything.
dumb person is offline   Reply With Quote
Old 10-08-2012, 05:20 AM   #16
BRENT in 10-uh-C
Yes in .005 and .015. I probably should have made myself a little clearer about the desire for .030 with the larger heal. Thank you for mentioning though.
BRENT in 10-uh-C
Old 10-08-2012, 08:33 AM   #17
Cajun
I had a similar problem with my engine. It turned out that the single nut adjustable lifter had moved. It is my understanding that there has been a problem with these becoming loose.
Cajun is offline   Reply With Quote
Old 10-08-2012, 11:08 AM   #18
Milton
Milton's Avatar
Yes Vince,
Thunder Road, saw that movie at the drive-in in my first Model A.
P.S. The admission to the movie was more than the cost of the car.
Milton is offline   Reply With Quote
Old 10-09-2012, 09:23 PM   #19
columbiA
Ive found that the lifter bores are more likely to be worn in a B as the lifter gallery is not flooded with oil like it is in an A.
columbiA is offline   Reply With Quote
Old 10-19-2012, 06:49 PM   #20
A BONED
A BONED's Avatar
A quick update: It looks like the aluminium cam gear has a little clearance (as it should) with the helical teeth of the crank gear. But the movement of the cam gear can be moved with just one finger meaning that it does not turn the camshaft as well. I would imagine to move the cam gear that is bolted tightly to the camshaft would require more effort.
I still haven't removed the cam gear yet, but am now expecting the cam to flop around a bit on the camshaft even though the cam gear nut is tight. There is however no horivontal movement of the gear (left to right). Is this a common issue? I have no real experience, but would this mean the two locating pins that locate the cam gear on the camshaft be worn? Or the cam gear locating pin holes be worn?
