I have a 28 special coupe which is very similar to a 29 coupe. The wire starts at the terminal box, runs through a small L shaped metal bracket mounted to the inside of the car on the lower passenger side terminal box screw. Next the wire runs across the inside to the top corner of the cowl panel. There is a special bracket available that is mounted the the front most cowl to gas tank bolt. The wire then runs along the row of gas tank mounting bolts to another bracket mounted on the rear most cowl to gas tank bolt (top side). The wire is hidden behind the cowl upholstery panel. Next the wire runs up behind the passenger side metal windshield pillar garnish. The wire then goes through the small opening at the top of the windshield post and then runs toward the wiper in the channel that the upholstery board fit into. You will notice that there is a small indentation on the passenger end of the channel for the wire to pass through. The wire then passes through the right most large hole and to the wiper post. If you have more questions, you can PM me. I will be out of computer contact until next Tuesday.
Rusty Nelson
