Old 07-02-2012, 08:09 AM   #1
JonCT
Default 1930 CC Pickup Help
I am currently working on a 1930 Closed Cab pickup. The cab started off as an AA cab that my father had re-done 35 years ago. I have since bought a "pickup" engine & chassis from a guy that was restoring a pickup but lost interest. I mounted the cab and it is about 3/4" to an 1" too far forward. The hood does not fit and the accelerator hits the firewall. Does anyone know the proper mounting position for a pickup cab? Is it possible the frame is from a car and the mounting holes are slightly different? Any help would be appreciated.
Jon
JonCT is offline   Reply With Quote
Old 07-02-2012, 08:49 AM   #2
Keith True
Keith True's Avatar
Default Re: 1930 CC Pickup Help
They are the same.If you are trying to line up the two bolts at the bottom of the door post with the two holes in the bracket on the frame the cab will be in the wrong place.Only one of those bolts actually goes through the bracket on some,and the other hole just uses a carriage bolt just through the wood body block.Start at the single bolt at the front,at the foot of the firewall.I think you'll be fine.
Old 07-02-2012, 11:00 AM   #3
JonCT
Thank you, I will start there. I put the cab on a couple years ago and I don't remember exactly what I did but I know I re drilled some holes to get the body blocks to mount up. Anybody have a photo of the correct mounting?
Jon
Old 07-02-2012, 07:36 PM   #4
Roger V
Roger V's Avatar
Re: Bolting Pickup Cab to Frame
2nd addition,The ford model A,A Color,Upholstery and production Facts Book by George De Angelis,Edward P Francis,Leslie R. Henry, Page 31
www.whidbeymodelaclub.com
The book that Gary WA refers to above is "The Model A Ford as Henry Built It" which is available at many Model A parts suppliers. The chart within states which hole in the frame is used and the fastener size for all body styles. Lots of other info too. Has been referred to as the "brown bible" over the years.
Roger V is offline   Reply With Quote
Old 07-02-2012, 09:16 PM   #5
Keith True
Keith True's Avatar
You shouldn't have to drill anything.There are some rear body mounts in different place on the later frames,but they are towards the rear and the changes don't apply to the pickups.
Old 07-02-2012, 10:28 PM   #6
Gary WA
Gary WA's Avatar
Try to save and make larger small print.
Old 07-02-2012, 10:37 PM   #7
Steve Plucker
First of all do you have a early 1930 (28-29 style) cab or the later 1930 style cab?
Second...The reason you may not be lining up, up front is because the front body mounting brackets, the ones with two holes in them, were moved sometime and this may be your problem in that the frame you have is not set up for your body style.
Go to my website and review the frame article I did for MAFCA a few years ago...this may answer your questions.
Pluck
Old 07-03-2012, 06:47 AM   #8
JonCT
It is a 30-31 Cab. Thank you for all the information. I will take some photos of my situation.
Jon
Old 07-03-2012, 08:20 AM   #9
1931 flamingo
1931 flamingo's Avatar
JonCT: where are you located??
Paul in CT
Old 07-03-2012, 08:39 AM   #10
JonCT
Paul I am in Lebanon.
Old 07-03-2012, 08:39 AM   #11
juke joint johnny
juke joint johnny's Avatar
Keith is right!! thats the way mine is
only one hole on the frame bracket lines up by the door post,
sounds like you need to push your cab back 2" then it will be Ok
John Cochran
juke joint johnny is offline   Reply With Quote
Old 07-03-2012, 11:35 AM   #12
700rpm
700rpm's Avatar
Lebanon? Like, the Middle East? Or Lebanon, Oregon? Or...?
Ray Horton, Portland, OR
Old 07-11-2012, 11:23 AM   #13
JonCT
Lebanon, CT - Sorry I have been away for the last couple days I will get a photo soon.
