Old 06-17-2012, 10:03 AM   #1
JBohannon
Default What is this?
At the bottom of the block about 2 or 3" directly above the oil pump I have a bolt. What is it and how tight should it be. Thanks. Joe B.
JBohannon is offline   Reply With Quote
Old 06-17-2012, 10:31 AM   #2
JoeWay
JoeWay's Avatar
Default Re: What is this?
It should be a 1/8" pipe plug with a slot for a flat screwdriver. Put a thin layer of pipe dope on the plug. Use a regular screwdriver and snug it up pretty good. It doesn't need to be REALLY tight.
Joe
1929 Tudor
since 1962
Feather River A's
JoeWay is offline   Reply With Quote
Old 06-17-2012, 10:47 AM   #3
pat in Santa Cruz
pat in Santa Cruz's Avatar
assuming the threads are still as originally designed, Joe Way is right. I have seen cases where the threads were tapped out or even enlarged from 1/8th pipe thread to 1/4 or straight threads. This usually happens because someone erroneously thought the plug was a set screw for the oil pump or to plumb an oil filter. If this is the case, measures need to be taken to plug the hole, but not to allow the plug to contact the oil pump housing. Tightening a screw or plug against the housing can cause it to crack.
pat in Santa Cruz is offline   Reply With Quote
Old 06-17-2012, 12:22 PM   #4
JBohannon
Thanks, It appears mine has been threaded to a 3/8 straight thread. I will put a short bolt with pipe dope I guess. Thanks.
Old 06-17-2012, 04:59 PM   #5
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
In a pinch, run a 1/8 NPT die clear down on a 3/8" SAE bolt, & it'll screw nicely into the block hole without "buggering" up the threads. Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 06-17-2012, 08:55 PM   #6
Bob C
Why not just use the right 1/8" pipe plug, they are a little bigger than the 3/8" bolt.
Bob
Old 06-17-2012, 09:15 PM   #7
BILL WILLIAMSON
Bob
Sorry, Bob,
I didn't mean the bolt thing to plug the hole, the bolt thing was when you're in a pinch for a "tool" to lock the pump when droppin' the pan. Bill W.
Old 06-17-2012, 10:27 PM   #8
Bob C
No problem Bill. I was just letting the OP know that the 1/8" pipe was larger than 3/8" bolt.
Bob
