Old 05-08-2017, 09:16 PM   #1
duke36
Default Idle RPM
Is there a good idle rpm range? I have a clamp-on tach to check.
Old 05-08-2017, 09:27 PM   #2
Utopia Texas
Utopia Texas's Avatar
Default Re: Idle RPM
I've never had a tach. on my '31 so I do not know.
I set it where I can hear the individual cylinders firing so I am
guessing 400 RPM more or less......
Utopia Texas is offline   Reply With Quote
Old 05-08-2017, 11:58 PM   #3
CarlG
CarlG's Avatar
500 (or so) works for me.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 05-09-2017, 12:01 AM   #4
RawhideKid
Since I have never had a tach on mine, I just adjust the idle screw til it quits and back it out ½ turn.
RawhideKid is offline   Reply With Quote
Old 05-09-2017, 02:29 AM   #5
johnbuckley
johnbuckley's Avatar
I reckon that anything less than 500rpm is within OK range. After a rebuilding of a carb I generally get them happy at 390-450 rpm but all cars are different
Old 05-09-2017, 06:19 AM   #6
Kurt in NJ
Kurt in NJ's Avatar
I adjust to walking speed in first gear at idle -with 1/3 advasnce--this way I don't have to ride the cltch when doing a parade, fine speed adjustment for speed is the spark advance---don't know the rpm, probably 350-400
Old 05-09-2017, 06:53 AM   #7
old31
Curious. What do you use for a tach?
old31 is online now   Reply With Quote
Old 05-09-2017, 09:07 AM   #8
40 Deluxe
You can use a digital tach that has a RPM scale. Not sure if they work on 6 V. but almost everybody has a jump box that will power it.
Old 05-09-2017, 10:07 AM   #9
duke36
I have a hand held " EZ Tach Digital" powered by a 9v battery. Works great on 2 or 4 stroke cycles, cars, etc. Not sure though how it will work on the A leads from distrib to plugs with auto advance FS ignition...
Old 05-09-2017, 10:26 AM   #10
johnbuckley
cheapo tachos available via ebay . They work by having their pickup wire adjacent to HT lead. Does not look period as digital and plastic but reasonably accurate against an old analogue ( do you guys spell it analog?) one. Unless their both wrong of course.?
Old 05-10-2017, 12:07 AM   #11
40 Deluxe
Good grief! I meant to say "digital timing light".
