Old 04-17-2012, 10:03 PM   #1
TD
TD's Avatar
Default Rear brake question
I'm replacing both emergency brake toggle lever bushing tubes and am planning to mig a tack weld on both. Is this all good or is there a better way?
Td
TD is offline   Reply With Quote
Old 04-18-2012, 04:15 AM   #2
johnbuckley
johnbuckley's Avatar
Default Re: Rear brake question
Why are you planning to do this?
Old 04-18-2012, 06:28 AM   #3
Kurt in NJ
Kurt in NJ's Avatar
I have used a 1" ball bearing and a press to swedge in the tube when it is loose or being salvaged from another plate--looks like the factory did it when finished
Old 04-18-2012, 08:52 AM   #4
Cider Mill
Cider Mill's Avatar
I also have swedged in the bushing tubes using the lug swedging tool from Brattons. It worked great, seems to be solidly in place, and looks good, but I haven't re-installed yet, so I can't say how it will hold up with use.
Cider Mill is offline   Reply With Quote
Old 04-18-2012, 08:56 AM   #5
Farrell In Vancouver
Farrell In Vancouver's Avatar
TD..........I buzzed mine with a mig and dressed it up with a dremel. Add black paint and it looks fine.
Farrell In Vancouver is offline   Reply With Quote
Old 04-18-2012, 10:06 AM   #6
TD
TD's Avatar
Yea - Mac's suggests a tack weld to hold it in place - I considered on the tube side tight at the base although I could flip it to the flat side and tack on the rim where both pieces meet
