Old 03-21-2012, 08:14 PM   #1
blgitn
blgitn's Avatar
Default Exhaust manifold pipe
All,
Is there a source for just the pipe from the exhaust manifold flange, with the 90* bend, to the muffler? Maybe somone has a used one they'd part with? Thanks.
R/ Roger.
blgitn is offline   Reply With Quote
Old 03-21-2012, 08:19 PM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Exhaust manifold pipe
I would think the local muffler shop could make you one easy in the well under 50$ range --in new thick wall pipe
Old 03-21-2012, 08:21 PM   #3
Barry B./ Ma.
Barry B./ Ma.'s Avatar
I think Brattons carries a straight section with a flange and 90deg. sections to add on can be bought at auto supply stores. Hope this helps.
Barry B./ Ma. is offline   Reply With Quote
Old 03-21-2012, 08:24 PM   #4
J Franklin
J Franklin's Avatar
I had a muffler shop make one once with an internal sleeve fabricated itegral with the flange that extended beyond the seam of the manifold and it did not cost much at all.
Old 03-21-2012, 08:30 PM   #5
jan bogert
jan bogert's Avatar
your local meineke, will make you one!
jan bogert is offline   Reply With Quote
Old 03-22-2012, 01:30 PM   #6
blgitn
blgitn's Avatar
Doh! I didn't even think of muffler shop! I'll check the Brattons catalog too.
Old 03-22-2012, 01:32 PM   #7
blgitn
blgitn's Avatar
Thanks!
Old 03-22-2012, 04:30 PM   #8
CarlG
CarlG's Avatar
I took my whole exhaust manifold and muffler/tail pipe down to the local muffler shop, they fixed me up great, and not much $$.
