Old 02-22-2012, 08:24 PM   #1
spdway1
spdway1's Avatar
Default What is the weight of a 29 CC Pick up?
What is the weight of a 29 Closed Cab Pick up?
I am trying to figure out if my daily driver can tow it safetly with an open trailer. Thank you.
spdway1 is offline   Reply With Quote
Old 02-22-2012, 09:20 PM   #2
700rpm
700rpm's Avatar
Default Re: What is the weight of a 29 CC Pick up?
About 2200 lbs.
Ray Horton, Portland, OR
Old 02-22-2012, 09:54 PM   #3
Bob C
The McMillan book says 2073 lbs.
Bob
Old 02-22-2012, 10:10 PM   #4
Wello
Wello's Avatar
My initial registration in California, following an out of state purchase, required a weight certificate since it was a commercial vehicle (go figure). Mine weighted in at 2300. The scale master laughed saying that my A was the lightest truck he has ever weighed.
Wello is online now   Reply With Quote
Old 02-23-2012, 12:36 AM   #5
700rpm
700rpm's Avatar
Originally Posted by Ed View Post
My 29 CCPU weighed 2415 pounds full of fuel, oil, and antifreeze. I believe the factory weights were without fluids.
Did that include the 35# of air in each tire?
Old 02-23-2012, 02:28 AM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
What's your daily driver and what's the trailer?
Any bad hills or mountains to cross?
Old 02-23-2012, 06:16 PM   #7
spdway1
spdway1's Avatar
2006 dodge durango with open trailer, MA to FL and return.
Thank you for all your responses!
Old 02-23-2012, 10:10 PM   #8
Bob C
Uhaul says it will work.
http://www.uhaul.com/Reservations/RatesTowing.aspx
Bob
