Old 01-31-2012, 12:49 PM   #1
Greg way out West
Question Point's setting ?
Hi guy's,,
I noticed in the first page of the Jan. 28 service bulletin's about setting the point's & timming. It call's for .015 to .018...I know it was latter changed to 18 to 22...
My old VW manuel called for .016 point's setting.. I'am thinking the 16 will give a hotter spark...BTW I'am using the New "B" point's cam the supplier's sell ... Any thought's about why Ford changed the setting at a latter date ?
Also alway had trouble with the "Rubbing block" wearing down real fast..Were the original's like that ?
Thanks,, Greg out west
Greg way out West is offline   Reply With Quote
Old 01-31-2012, 01:03 PM   #2
RonC
RonC's Avatar
Default Re: Point's setting ?
The rubbing block will wear initially when new. As soon as you notice the change in timing just reset your points. Make sure you add point block grease to the cam. Ford engineering determined that a point setting of .018" to .022 worked best.
RonC is offline   Reply With Quote
Old 01-31-2012, 01:50 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
The B cam will give more dwell for a hotter spark. The speed of the Model A engine and only 4 lobes on the cam gives enough dwell anyway, without going to a closer setting. As Ron states, a clean well lubed cam should give long wear on the points block. I'm not familure with wear on new points because I'm stll using old original points.
Old 01-31-2012, 03:59 PM   #4
Tom Endy
Tom Endy's Avatar
I have been setting Model A points at .020 for years and the car runs well, until the points close up. This will certainly happen with reproduction points. Like Tom above, I use old original points I salvaged out of cruddy distributors. I just keep filing the points and re-setting them. The only reason I would discard them is if after many years and miles of use the rubbing blocks wear enough to allow the arm to short out.
Tom Endy
Old 01-31-2012, 07:09 PM   #5
Mike V. Florida
Mike V. Florida's Avatar
Everything you you ever needed to know about timing the Model
A.
http://www.abarnyard.com/workshop/timing.htm
Old 01-31-2012, 09:23 PM   #6
Marco Tahtaras
Marco Tahtaras's Avatar
There are many aspects that I believe are being overlooked or misunderstood. Now I may be out to lunch (missing something) but this is my take on it:
1. The smaller the point gap the greater the risk of the points arcing which of course is a great way to shorten the useful life span of your points (among other things).
2. Dwell angle is WAY over emphasized in our application. I assume most have heard of the relationship between dwell and coil saturation time. TIME is the key word. An engine spinning 1250 RPM has FOUR TIMES the amount of time to reach peak intensity as does the same engine spinning 5000 RPM. Most of the folks that seem to "dwell" on this issue will rarely spin higher than 2000 RPM! If you indeed have a weak spark look elsewhere.
3. On later cars with factory specs for both point gap and dwell, unless a distributor is badly worn setting the points and setting the dwell are in fact the same. If you can get a clean read with a feeler and set point gap to specs, the dwell will read exactly correct. I've found in these conditions the ONLY time there is a benefit to a dwell meter is when the points can be adjusted with the engine running.
Marco Tahtaras is offline   Reply With Quote
