Old 01-04-2012, 09:49 PM   #1
700rpm
700rpm's Avatar
Default Clarification: How to add fluid to late 30's (38-39)shocks?
I have a set of late 30's, maybe 1938 or 1939, replacement shocks on my coupe. What do I refill them with, and what is the best method of doing this?
Ray Horton, Portland, OR
Old 01-04-2012, 10:22 PM   #2
Bill Stipe
Bill Stipe's Avatar
Default Re: How to add fluid to late 30's shocks?
Ray if they a repro stocks from the catalog stores most likely they have a fake reservoir and the oil will not go anywhere plus there is no ajustment. They get air in the wing shaft chambers and they will no longer function properly.
I maybe wrong but my guess is that is how they are.
Good Luck
Bill
www.stipemachine.com
Building Horse Power --
Bill Stipe is offline   Reply With Quote
Old 01-04-2012, 10:44 PM   #3
Milton
Milton's Avatar
I used 30w and filled them to the brim and adjusted the damping.
Milton is offline   Reply With Quote
Old 01-05-2012, 09:14 AM   #4
jw hash
jw hash's Avatar
Red Rocket is correct, the repo`s I have took apart to see how they are made do not have oil in the reservoir they only have oil in the chamber,
jw hash is offline   Reply With Quote
Old 01-05-2012, 10:12 AM   #5
Bruce Adams
Bruce Adams's Avatar
The originals have a square nut that is an obvious filler location.
I use vendor provided "Shock Absorber Fluid" that is clear and I have heard is glycerin. It does not smell to me like motor oil.
Bruce Adams is offline   Reply With Quote
Old 01-05-2012, 10:27 AM   #6
Barry B./ Ma.
Barry B./ Ma.'s Avatar
I've used hydraulc jack oil or STP. The rebuilder of my new shocks uses STP and they are fine. Don't add oil to repro shocks even if there is a fill plug, that's just there for looks.
Barry B./ Ma. is offline   Reply With Quote
Old 01-05-2012, 11:19 AM   #7
jhowes
Barry B. What do you mix the STP with and what ratio? Mine are rebuilt old shocks. Jack
jhowes is offline   Reply With Quote
Old 01-05-2012, 11:58 AM   #8
700rpm
700rpm's Avatar
My original post was misleading, I think. These are not post 1970-reproduction Houdaille shocks. These are shocks that were made in about 1938-39 to replace the original Model A shocks, or so I was told. They look similar to V8 shocks, and/or may actually be V8 shocks.
Maybe this question belongs on the V8 site (?).
Old 01-05-2012, 12:22 PM   #9
spinelll
spinelll's Avatar
Default Re: Clarification: How to add fluid to late 30's (38-39)shocks?
Are those V8 shocks bending your rear service rods by any chance?
spinelll is offline   Reply With Quote
Old 01-05-2012, 12:42 PM   #10
700rpm
700rpm's Avatar
No evidence of that.
Old 01-05-2012, 08:25 PM   #11
Barry B./ Ma.
The rebuilder told me he uses STP straight. An older guy had many shocks at Hershey that he rebuilt and had a test gauge there, they tested out well at 60/40. Barry B.
Old 01-05-2012, 09:40 PM   #12
columbiA
I just use 90 gear oil in my shocks & seems to work fine.On my 30 cpe I am useing 36 front shocks on the rear & they clear the brake rods fine,but Im useing a Columbia OD from a 40 ford that is slightly wider.On the front the same shocks would rub on the brake rods.Shocks from 28-36 have same mounting bolt spaceing but 37-48 are wider.
columbiA is offline   Reply With Quote
Old 01-06-2012, 10:48 AM   #13
Bruce Lancaster
As far as I know, V8 lever shocks from '32-48 ('47-48 they were phasing out in favor of tube shocks) all had an obvious filler plug up near the top. Maybe these are something else entirely?? Is there someone in your local chapter who could post a picture?
Old 01-06-2012, 01:33 PM   #14
700rpm
700rpm's Avatar
I can see the plugs. I was just wondering how you get the fluid into those little holes. Turkey baster?
Old 01-06-2012, 01:36 PM   #15
1931 flamingo
1931 flamingo's Avatar
If these are earlyV8 shocks try posting on the EV8 board.
Paul in CT
Old 01-06-2012, 02:17 PM   #16
Bruce Lancaster
Or buy an oil can/squirter as dedicated shock tool. A cheap plastic one would also cut down into a good funnel since the little hole is so small.
Joblot used to sell their shock stuff in a tin with a cap that could be screwed on with an integral funnel soldered sideways to closing cap...
Old 01-09-2012, 01:47 PM   #17
Bruce Lancaster
I just thought of the perfect modern/available shock fillerupper: Check out the nearest store display of Auto fluids. Some of the substances like power steering fluid come in a version of a normal quart oil bottle that has a cap with a built in funnel tip that necks down to realdamnsmall, perfect for the little filler hole in shocks. Buy something your modern wheel can use some day, steal the nice cap and put it on a clean bottle for your shock fluid. At last, a possible replacement for the long departed Joblot tin cans...
