Old 01-03-2012, 04:32 PM   #1
Firepower flyer
Firepower flyer's Avatar
Default Trans ID help
I got a side shift trans that came with a pile of parts I bought and he thru the trans in,po thought it was a Merc trans.The number on the back of the trans is as follows O1A 7006 and up top where they stamp serial numbers is *I8-579302I* If it turns out to be a 3sp ford or merc can I use the gear cluster in a top loader case?
Thanks Joe
Firepower flyer is offline   Reply With Quote
Old 01-03-2012, 06:37 PM   #2
rotorwrench
rotorwrench's Avatar
Default Re: Trans ID help
You can check Mac VanPelt's web sight for the serial numbers. With that number it would be pre-war 221 CID Ford application. Mercury would be 99-XXXXXX on the top of the trans. The gears will interchange with a top shift type but just make sure the input gear tooth count will work for your application. 16/28 is the most common on the passenger cars.
Kerby
Old 01-03-2012, 07:06 PM   #3
Mike in AZ
Mike in AZ's Avatar
i think you'll find in the link that it's a '40 trans....i think....lol.....and what Kerby said....Mike
http://www.vanpeltsales.com/FH_web/f...ialnumbers.htm
Mike in AZ is offline   Reply With Quote
