Old 10-22-2021, 10:56 AM   #1
JD-OHIO
JD-OHIO's Avatar
Default Free Up Key Mechanism on outside door handle
I took the out side door handle with the lock in it to a local locksmith and he said that the insides were corroded enough that he could not get it to turn or be able to put a key in enough to turn it. The handle looks great so I can still use it but I would like to be able to lock the car. It's from the passenger side of my '31 Town Sedan. Any ideas of how to get it cleaned out ?
JD-OHIO is offline   Reply With Quote
Old 10-22-2021, 11:08 AM   #2
bavArian
bavArian's Avatar
Default Re: Free Up Key Mechanism on outside door handle
I'd try a good penetrating oil. (NOT WD40, that's not good for lubricating things, only for cleaning things )
Thoroughly drench the insides in it and let it sit for a day or two, then try again. Eventually it should free up.
bavArian is offline   Reply With Quote
Old 10-22-2021, 11:11 AM   #3
Oldbluoval
Oldbluoval's Avatar
Send it to Howard Denker in Omaha
The cylinders are fragile and normal locksmith will break them and render the cylinder useless.
Post a pic of the front of the handle. Is it a Crown or B&S? Off a TS likely a B&S
Do you have the correct key for it?
Old 10-22-2021, 11:19 AM   #4
JD-OHIO
JD-OHIO's Avatar
No, I took it to the locksmith to get a key.
Old 10-22-2021, 11:22 AM   #5
JD-OHIO
JD-OHIO's Avatar
I need contact info for Howard Denker.
Old 10-22-2021, 03:38 PM   #6
Oldbluoval
Oldbluoval's Avatar
[email protected]
