Old 08-29-2011, 11:09 PM   #1
1930artdeco
1930artdeco's Avatar
Smile finally home
Well after putting lots of money into my baby we loaded her and the chase car up and set off for California on Sat. The first part of the trip consisted of making it over the Siskyu pass, through Shasta and to Willows for the night. No major problems occurred-fortunately. On Sunday we drove down 99W through the central valley in 101 degree temps and I had a blast. I got more heat from the firewall than outside.
99W is a great road to drive, the speed is the same as on the freeway-for me at least. There was no traffic and the scenery was fantastic and extremely relaxing. That afternoon we got to Livermore and put her to bed. The only real problems that I encountered were that if I stopped suddenly she would die quietly. I got pretty good at revving her up at stop signs to keep her going. I am figuring a fuel blockage somewhere. The other problem is that the steering got looser. I started out with about 2 inches of free play and ended with about 4 inches. But the nice thing is, she drove and steered just fine over a really good Model A road. So now, I am dreaming of the rest of the car show/touring season and going in my car.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 08-29-2011, 11:22 PM   #2
Mike V. Florida
Mike V. Florida's Avatar
Default Re: finally home
Feels good don't it?
Old 08-30-2011, 08:33 AM   #3
1930artdeco
Yes it does.
1957 Country Sedan
Old 08-30-2011, 08:46 AM   #4
TinCup
TinCup's Avatar
Sounds like your float level is too low and when you pull up to start it's starving for gas. Common problem and easy fix. Nothing like a road trip, good luck.
TinCup is offline   Reply With Quote
Old 08-30-2011, 09:18 AM   #5
bogdonj
bogdonj's Avatar
I have the same problem with the Carb.. i'm getting really good at controlling the rev when coming to a stop... Eventually I will take the carb apart and have a look. Congrats on the solid trip!
_________________________________________
1931 Ford Model A Tudor
1930 Ford Model A Deluxe Roadster
1930 Ford Original Rolling Chassis- Restoring
bogdonj is offline   Reply With Quote
Old 08-30-2011, 09:30 AM   #6
glenn in camino
glenn in camino's Avatar
Loosening steering could be caused by the pitman arm being loose on the steering shaft. Have someone turn the steering wheel back and forth while you look to see if the shaft turns before the pitman arm moves. If it does, tighten the nut and reinstall the cotter pin.
Old 08-30-2011, 10:06 AM   #7
Jack '29 Sport Coupe
Jack '29 Sport Coupe's Avatar
Nice pics! Exactly where was the starting point? Mileage?
Jack
Cincinnati, Ohio
Jack '29 Sport Coupe is offline   Reply With Quote
Old 08-30-2011, 03:38 PM   #8
1930artdeco
We went from Medford, Or to Livermore Ca. I am guessing about 300+ miles.
1957 Country Sedan
