I'm pretty sure I already know the answer to this, but here goes anyway:
The other day I came across stainless 30-31 Model A repro radiator caps being sold on ebay by a place called Classic Auto Parts Group Inc. The picture in the description was fuzzy but the 'buy it now' price was under $10 so I took a gamble. Got the part in the mail and it looks more than acceptable for the money. -now my question: Upon flipping the cap over, I noticed that there is a small vent hole drilled in the underside. I contacted the seller about this and he informed me that 'it's supposed to be that way' since the model A has a non-pressurized cooling system. Now, maybe I'm a dope, but I dont believe that any of the other old wore out A caps I have, have a vent hole. Is there supposed to be one??? Seems to me that when the coolant level comes up in the top tank, it's gonna escape that hole and end up on the hood. Thanks for your insight! -Brian |
Brian,
What you have is a gas cap. There shouldn't be a hole in a radiator cap. Jon Last edited by JBR; 07-07-2011 at 11:41 AM. Reason: hit wrong key. |
Thanks JBR - I thought it was a gas cap at first also. However, the outter shell of the cap has the lower skirt like a radiator cap would. It also has the smaller center piece (the part with ears that thread down into the radiator neck). I havent tried it yet, but I dont believe this center piece is large enough to engage the filler neck hole for the gas tank - I think the gas cap has a larger center. Perhaps these caps just come from a confused manufacturer? I guess for the $10 initial investment, I can afford to plug the hole with a dab or solder or JB weld and away I go!
-Brian |
what does the inside of the cap look like and is there a letter on the rivets and there is NO vent hole in any of the original model A radiator caps, is it stainless outside or chrome plated steel it sounds like it could be a badger cap sold by western auto if so the vent is only in the catch part and there will be a letter B on the rivets I have some of them in the original box,
![]() Thanks -Brian |
