Old 07-05-2011, 05:56 PM   #1
Marcus
Marcus's Avatar
Talking Just MY Experience......
ALL: NOT trying to start another arguement about "A" brakes, but here is MY experience: 1931 Model A Slantwindow, and the brakes needed replacing; as well, one of the brake rods was bent. I purchased the Deluxe set of "Floaters" from Flathead Ted, and my good friend, Allen Danner, installed them, along with cast iron drums and brand new shoes plus rods all around. The difference is absolutely incredible! NOW, with very little effort, you can lock and slide all four tires. I would compare the braking to a power unit, because of the greatly reduced pressure required to engage the brakes. I would STRONGLY recommend the floaters - The feeling of safety is invaluable!!
WARM REGARDS, MARCUS
Marcus is offline   Reply With Quote
Old 07-05-2011, 06:51 PM   #2
Fred K-OR
Fred K-OR's Avatar
Default Re: Just MY Experience......
Thanks Marcus. Sounds like a great way to go.
I am in the process of doing the same thing as you did for my coupe. The only difference is that I did not go for the Floaters (maybe I should have) and new brake rods (mine looked good). The rest of the stuff I replaced with new items-cast iron drims, rollers, wedges, etc. I will keep my fingers crossed and hope I will have reasonable success with what I have done.
Thanks for the comments about your process.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 07-05-2011, 09:29 PM   #3
Jack '29 Sport Coupe
Jack '29 Sport Coupe's Avatar
I've heard the same thing about Ted's floaters from the guy who had installed hydraulics in mine back when he owned it. He said that he much preferred Ted's to the hydraulics. I acquired my first A back in 1962 and it had mechanicals. The
juice brakes didn't seem that much better to me. I guess my next stop will be Ted's.
Jack
Cincinnati, Ohio
Jack '29 Sport Coupe is offline   Reply With Quote
Old 07-05-2011, 11:33 PM   #4
Mike V. Florida
Mike V. Florida's Avatar
After adjusting and replacing worn parts on the stock system I too can lock up all four wheels with little pressure.
I will say that if you are not willing to keep up on shoe adjustments you will wear out one half the shoe and Teds set up should allow for even wear.
