Old 05-07-2011, 01:49 PM   #1
bobgreco
bobgreco's Avatar
Question Thermostats
I read the posts on thermostats and understand that some use them and some don't. What I am wondering is whether they came with one from the factory?
bobgreco is offline   Reply With Quote
Old 05-07-2011, 04:10 PM   #2
Aerocraft
Aerocraft's Avatar
Default Re: Thermostats
It is my understanding that they were not factory original equipment. Gar Williams
Aerocraft is offline   Reply With Quote
Old 05-07-2011, 04:15 PM   #3
1931 flamingo
1931 flamingo's Avatar
Time's two.
Paul in CT
Old 05-07-2011, 07:09 PM   #4
Special Coupe Frank
Special Coupe Frank's Avatar
FYI - while the Model A did not have a thermostat from the factory.
Contemporary Lincolns did, and Cadillac and Packard both used "water-throttling" Thermostats ( as opposed to radiator shutters) since 1914 and 1916 respectively.
And Ford began using them in the V-8 by the mid-1930's.
SC Frank
Special Coupe Frank is offline   Reply With Quote
Old 05-07-2011, 07:19 PM   #5
glenn in camino
glenn in camino's Avatar
They are not original equipment, but if you live in a cold climate, and drive your Model A in winter, they do warm up your engine in a few miles. I have one, 160 degree, that I bought from Brattons in my deluxe delivery that I run year around. The cooling system is clean and the radiator has been recored.
Old 05-07-2011, 08:32 PM   #6
Bill Steiner
Not org. I don't use one, but I do live in Texas and not much cold weather. Bill
Bill Steiner is offline   Reply With Quote
Old 05-07-2011, 08:33 PM   #7
bobgreco
bobgreco's Avatar
Many thanks as always!
Old 05-07-2011, 09:18 PM   #8
Special Coupe Frank
After replacing the head-gasket in my '28 Coupe, I also replaced the water outlet, as the original one had a broken mounting ear that had been brazed.
I got a replacement that has a 1/2" NPT tapping, and installed a mechanical temperature gauge under the dash.
Ran the car all summer long w/o a thermostat - would take the car a good 1/2 hour of running to get up to 140* F , and it rarely went above that.
That's really too cool for efficient operation and greatly contributes to condensation in the crankcase, which aren't ventilated very well to begin with in a Model A.
In late September, as the weather cooled, my engine wasn't even breaking 120-130*. I installed an "upper-hose" thermostat from Bratton, 160 *.
Now my engine is up to operating temperature in a couple miles / five-eight minutes.
We 've had some pretty warm days this spring, and I've run it hard - stays around 160*, never exceeds 170*.
Can't imagine running one w/o a stat now.
SC Frank
Old 05-07-2011, 11:05 PM   #9
JtownJoe
JtownJoe's Avatar
Ditto, I have to use one to keep the tepm. in the 160 to 180 range.
JtownJoe is offline   Reply With Quote
Old 05-08-2011, 09:07 AM   #10
John LaVoy
John LaVoy's Avatar
Several years ago we did an article in the Model A Times explaining the need for a thermostat because of the fuel blends being sold today. The engine has to be above 160 degrees to get a complete clean fuel burn.
John LaVoy is offline   Reply With Quote
